chanduj
Regarding Libraries in SDK/EDK
  I am beginner to xilinx (XPS, EDK/SDK). I run the hello world program in SDK. It shows the error like
**** Full rebuild of configuration Debug for project system ****
make clean all
rm -rf main.o    main.d    system.elf
powerpc-eabi-gcc -ID:/EDK/ppc405_0/include -O0 -g -c -omain.o ../main.c
../main.c:5:25: xparameters.h: No such file or directory
make: *** [main.o] Error 1
Build complete for project system
Hello world program
* Filename : test_uartlite_9600.c
* on the STDOUT device
#include "xparameters.h"
int main() {
xil_printf("Hello World \n");
return 0;
Could u give suggestion 2 me how to add "xparameters.h" and "xutil.h"  I need information urgent
prateek_bhatt
Hello.
This file is available to you after you do generate libraries and BSP. The location of this file is in your software project itself in XPS. Expand processor by clicking on "+" sign.
Best of luck.
Unlimited in my Limits.
chanduj
Dear sir,
 As u said i follow the way
In project information area  tab -> in APPlICATION -> select Processor: PPC405_i -> generated header -> In that i modify or add header file
#define XPAR_CPU_PPC405_xparameters_lib_libxil.a
Is the corrcect way added lib file?
Kindly reply 2 me.
prateek_bhatt
Hello.
I never added the lib file corresponding to xaparameters.h
I always used it as it is.
 I never used
Try removing xparameters.h and add stdio.h. See if that file is recognised.
Best of luck.
chanduj
Dear sir,
   I used xparametrs as ur way but when i store this program in SDK it build defaulty and shows error for header files. kindly help me
e../main.c:5:25: xparameters.h: No such file or directory
dorau
Hi chanduj,
please look into the directory "edk-subproject-dir/ppc405_xxx" whether the file xparameters.h is available or not.
If not, you must generate libraries and BSPs first!
Rgds,
Kai
