Visitor mahirztrk
Removing Unused functions from Assembly Code
   I wrote an extremely  simple program in SDK  11.1.  I've expected a small sized program that would be fit in a 4K block RAM, but it didn't. When I  looked
the assembly code (with mb-objdump -S). I realized something strange that compiler added some functions to assembly code even i didnt use them directly
or indirectly like XIntc_Disconnect, XIntc_Stop (Actually, all the functions in the intc driver were added). How can i remove these? Any idea?
(I tried to build the project with area optimization enabled, but it didnt work.)
Tags (2)
Re: Removing Unused functions from Assembly Code
4k is very tiny. Using "-Os" won't be enough (as you have discovered).
Look at the "-ffunction-sections" GCC option. This will help with the "unused" stuff noted below (compile the BSP itself with this, not merely your application). With only 4K you can pretty much forget about using standard library functions though.
-Brian
-Brian
You'll also need
-Wl,-gc-sections
for the linker to take advantage of my previous note.
Visitor mahirztrk
Thanks brianhill, it worked perfectly.
