Restore Default SDK Popup Behavior
I have SDK running on a PC where the Popup will no longer come up because the checkbox
was checked to no longer bring up the launcher.  How can I get the popup to start coming up
after the check box has been checked.
Window -> Preferences -> General -> Startup and Shutdown -> Workspaces -> Prompt for workspace on startup
Thank You David
