SDK 14.7 interrupt vector table not complete when import project
I am using XPS and EDK 14.7 with Spartan6 LX9 Microboard. I am generating XPS system and SDK project using step described in document AvtS6LX9MicroBoard_SW201_lwIP_Apps_14_4_01.pdf.
The harware project has three source of interrupt: MAC ethernet, AXI Timer and AXI Uartlite.
Software project is not working because Microblaze interrupt vector table is not initialized correctly, when an interrupt is asserting there is a crash. This is a fragment of map file:
.vectors.reset             0x00000000              0x8
*(.vectors.reset)
.vectors.reset
                                     0x00000000            0x8            c:/xilinx/14.7/ise_ds/edk/gnu/microblaze/nt/bin/../lib/gcc/microblaze-xilinx-elf/4.6.4/../../../../microblaze-xilinx- elf/lib/bs/m/le/crt0.o
                                        0x00000000                     _start
.vectors.sw_exception
*(.vectors.sw_exception)
.vectors.interrupt
*(.vectors.interrupt)
.vectors.hw_exception
*(.vectors.hw_exception)
It is missing data about other entry point than .reset.
In fact in an other point of map file I see that some vector table entry point are discarded:
Discarded input sections
.data                0x00000000     0x0                       c:/xilinx/14.7/ise_ds/edk/gnu/microblaze/nt/bin/../lib/gcc/microblaze-xilinx-        elf/4.6.4/../../../../microblaze-xilinx-elf/lib/bs/m/le/crt0.o
.bss                 0x00000000     0x0                       c:/xilinx/14.7/ise_ds/edk/gnu/microblaze/nt/bin/../lib/gcc/microblaze-xilinx-        elf/4.6.4/../../../../microblaze-xilinx-elf/lib/bs/m/le/crt0.o
.vectors.sw_exception        0x00000000 0x8    c:/xilinx/14.7/ise_ds/edk/gnu/microblaze/nt/bin/../lib/gcc/microblaze-xilinx-        elf/4.6.4/../../../../microblaze-xilinx-elf/lib/bs/m/le/crt0.o
.vectors.interrupt                  0x00000000 0x8    c:/xilinx/14.7/ise_ds/edk/gnu/microblaze/nt/bin/../lib/gcc/microblaze-xilinx-        elf/4.6.4/../../../../microblaze-xilinx-elf/lib/bs/m/le/crt0.o
.vectors.hw_exception        0x00000000 0x8    c:/xilinx/14.7/ise_ds/edk/gnu/microblaze/nt/bin/../lib/gcc/microblaze-xilinx-        elf/4.6.4/../../../../microblaze-xilinx-elf/lib/bs/m/le/crt0.o
I don't know why this sections are discarded. If I repeat same step with EDK and XPS 14.4 it si all ok and my vector table is complete.
If I generate a sw project using SDK wizard it is all ok, if I import a project I have an interrupt vector table not complete. How can I fix this issue?
I attach map file for documentation.
Begos
Re: SDK 14.7 interrupt vector table not complete when import project
Just regenerate the linker script.
The old linker script is not compatible with 14.7
Best regards
Lasse
Best regards
Lasse
I have regenerated linker script and now It works fine. SDK 14.7 needs keywords KEEP in vector interrupt labels.
Begos
