Observer jfrenzel
SDK 2014.4 breakpoints broken
I am running the SDK 2014.4 under Windows 7 Pro 64-bit. Debugging of my C program using breakpoints and single stepping was working great when I left work on Friday and when I returned on Monday the program no longer halted at main() on startup, nor did the the breakpoints in the C code work. (They also changed appearance - from tiny circles to either a slash or an X,  I can't tell. The only thing I can figure is that either the weekend Windows update or updating Java broke it. I reverted to Java 7, but no go.
Is there anyway to restore some default settings to the debugger in case I inadvertently changed something?
Re: SDK 2014.4 breakpoints broken
You can restore to defaults behavior of the SDK interface in the Preferences dialog box. Select Window > Preferences to open it, and click Xilinx SDK or or Run/Debug in the preference page to reset.
Praveen
Observer jfrenzel
I'm afraid that didn't fix the problem. I still can't get any breakpoints to work. When I click on the a line in the C file it shows a little blue circle (as when it was working) but now there is a larger blue slash through it, which would seem to indicate a broken breakpoint. However, when I hover over it with the mouse it says "Line breakpoint: ... ".
But when I his run, it just goes, and goes, and goes. (The C code and my PL are working though.)
