SDK 2014.4 crashes openning a terminal
Hi all,
I'm trying to open an UART Terminal. I change Terminal Settings, click OK and after some seconds SDK crashes.
I'm running Vivado in Ubuntu 16.04.
The error I have is:
****** Xilinx Software Development Kit
****** SDK v2014.4 (64-bit)
  **** SW Build 1071353 on Tue Nov 18 16:48:31 MST 2014
    ** Copyright 1986-2014 Xilinx, Inc. All Rights Reserved.
Launching SDK with command /opt/Xilinx/SDK/2014.4/eclipse/lnx64.o/eclipse -data /design -Xms64m -Xmx512m
Experimental:  JNI_OnLoad called.
# A fatal error has been detected by the Java Runtime Environment:
#  SIGSEGV (0xb) at pc=0x00007f532ed36a6a, pid=1371, tid=139998185023232
# JRE version: Java(TM) SE Runtime Environment (8.0_05-b13) (build 1.8.0_05-b13)
# Java VM: Java HotSpot(TM) 64-Bit Server VM (25.5-b02 mixed mode linux-amd64 compressed oops)
# Problematic frame:
# C  [librxtxSerial.so+0x7a6a]  Java_gnu_io_RXTXPort_nativeDrain+0xea
# Failed to write core dump. Core dumps have been disabled. To enable core dumping, try "ulimit -c unlimited" before starting Java again
# An error report file with more information is saved as:
# /root/hs_err_pid1371.log
# If you would like to submit a bug report, please visit:
#   http://bugreport.sun.com/bugreport/crash.jsp
I tried to enable core dumping but it still crashing.
Any ideas? Thank you in advance!
Re: SDK 2014.4 crashes openning a terminal
Hi @cluna.aistechspace
I guess that this issues is related to the following post:
https://forums.xilinx.com/t5/Embedded-Development-Tools/SDK-2014-4-crashes/m-p/884399/highlight/false#M46543
If so lets "close" this one (mark as solution) and focus on the other one.
Ibai
Ibai
Ibai
Ibai
