6l20
SDK 2015.03 missing file in "Helloword" template
Hi all,
I have generated my design with Vivado 2015.3 targeting a Zedboard (Zynq 7020) and launched SDK with the basic "Helloword" template.
It goes to error with the following message:
'Building file: ../standalone_bsp_0/ps7_cortexa9_0/libsrc/standalone_v5_2/src/profile/_profile_clean.c'
'Invoking: ARM gcc compiler'
arm-xilinx-eabi-gcc -Wall -O0 -g3 -c -fmessage-length=0 -MT"standalone_bsp_0/ps7_cortexa9_0/libsrc/standalone_v5_2/src/profile/_profile_clean.o" -ID:/Xilinx/2015-3_project/zynq_rx_syn_test/SDK_geops/standalone_bsp_0/ps7_cortexa9_0/include -MMD -MP -MF"standalone_bsp_0/ps7_cortexa9_0/libsrc/standalone_v5_2/src/profile/_profile_clean.d" -MT"standalone_bsp_0/ps7_cortexa9_0/libsrc/standalone_v5_2/src/profile/_profile_clean.d" -o "standalone_bsp_0/ps7_cortexa9_0/libsrc/standalone_v5_2/src/profile/_profile_clean.o" "../standalone_bsp_0/ps7_cortexa9_0/libsrc/standalone_v5_2/src/profile/_profile_clean.c"
In file included from ../standalone_bsp_0/ps7_cortexa9_0/libsrc/standalone_v5_2/src/profile/_profile_clean.c:34:0:
../standalone_bsp_0/ps7_cortexa9_0/libsrc/standalone_v5_2/src/profile/_profile_timer_hw.h:88:21: fatal error: xintc_l.h: No such file or directory
#include "xintc_l.h"
compilation terminated.
make: *** [standalone_bsp_0/ps7_cortexa9_0/libsrc/standalone_v5_2/src/profile/_profile_clean.o] Erreur 1
15:14:36 Build Finished (took 17s.588ms)
In the file "_profile_timer_hw.h":
#ifdef TIMER_CONNECT_INTC
   #include "xintc.h"
#endif /* TIMER_CONNECT_INTC */
#if (!defined PPC_PIT_INTERRUPT && !defined PROC_CORTEXA9)
   #include "xtmrctr_l.h"
#endif
#ifdef PROC_CORTEXA9
   #include "xscutimer_hw.h"
   #include "xscugic.h"
#endif
The missing file ("xintc_l.h") is called because TIMER_CONNECT_INTC seemed defined.
It seems that SDK does not take in account that I'm working with CORTEX A9.
Does anyone already have this problem ?
Thanks for your help.
Sylvain
bwiec
Hi Sylvain,
Did you enable the TTC timer in your hardware when you configured the PS7 block?
www.xilinx.com
6l20
Hi bwiec,
Yes, the TTC0 is enabled in the PS7 block.
I relaunch the flow without TTC0 to see if it works and keep you informed.
Nevertheless I need it in my design ...
6l20
I confirm that the "Helloword" template compile correctly in SDK without the TTC0 in PS7.
What can we do to be able to use the TTC ?
Sylvain
pvenugo
Could you share the SDK workspace so that I can run at my end and check.
Praveen
6l20
Hi Praveen,
Sorry for late reply.
Attach is the SDK Workspace and the SDK project repositories.
Sylvain
6l20
Praveen,
did you had time to investigate on the problem ?
Sylvain
I'm having the same issue. Could you find a solution?
Dosto
My issue resolved after upgrading my project (whose bsp was generated with 2017.3) to be compatible with SDK 2018.3.
