jcruza
SDK 2016.1 and standalone v5.4 with LWIP possible cache problems (ZYNQ)
I recently upgraded to Vivado and SDK 2016.1. No problems about Vivado HW part but I found problems.
The most important issue is about new standalone v5.4 and LWIP.
I upgraded but my network applicatios (LWIP RAWMODE) did not work. I thought that problems becomes from my applications but built in echo server example didnt work also.
It is a old known problem (many other posts with older versions had similar problems), see below:
https://forums.xilinx.com/t5/Embedded-Development-Tools/LWIP-flips-bytes-when-receiving-large-amounts-of-data-via-TCP/td-p/550526
https://forums.xilinx.com/t5/Embedded-Development-Tools/LwIP-library-on-Zynq-broken/td-p/595268
In short, half of the packets are rejected and connection resets continowusly, getting a bandwidth throughput ridiculously low.
The problem "solves" if you completely deactivate D-cache. Is not enough if you just invalidate cache data, thus, I think the cache problem arises inside lwip functions.
My thought is that are something wrong in standalone v5.4, cache functions or lwip driver.
I think it is an important issue.
My temporaly solution is simple: I am using now SDK 2015.4 with standalone v5.3.
I tried to work with SDK 2016.1 and standalone v5.3 but I couldnt because there was an error when compiling BSP.
All test has been done over Zedboard (7Z020) and Avnet's Mini Module Plus (7Z100), with and without hardware configured.
To reproduce a basic test:
1-Open Vivado 2016.1
2-Create a basic HW platform with board preset. Get bitstream and export to SDK.
3-Create built in echo app with its own bsp.
4-Open protocol analyzer (i.e. wireshark) filtering ip.addr == 192.168.1.10 (or any other)
5-Start echo app on board.
6-Telnet to echo server (telnet 192.168.1.10 7)
7-Write on telnet console and you can see the important delay. In protocl analyzer you can see something is worng.
8- Now deactivate d cache on main function: Xil_DCacheDisable();
9-Repeat 5 to 7 and you will see now everything is fine.
Any solution? Better wait 4 moths and hope 2016.2 will be fixed? Doing something wrong?
Thank you.
Tags (4)
kylebatzer
Check out this topic: "LWIP echo server example drops/delays TX packets on Zedboard ?".  Changing cache options in the init_dma call worked for me.
jcruza
Still happening exactly the same on 2016.2.
kylebatzer
I noticed the same issue with pings on 2016.1 using the echo_server example application.  About half never receive a reply.  The same test on 2015.4 had no lost communication.
I am using a microzed board.
kylebatzer
jcruza
Still happening with SDK 2016.4
I don’t understand why this isn't solved yet.
jcruza
Thanks kylebatzer.
As its posted in that topic, I tried the code after xemac_add call and it works fine:
// Fix delayed Ethernet transmission problem
extern u8_t bd_space[0x100000];
Xil_SetTlbAttributes((s32_t)bd_space, STRONG_ORDERED );
