SDK 2017.2 xilsf 5.8 library does not compile
I am trying to use Wibond W25Q series SPI Flash with SREC SPi bootloader.
I created an SREC SPI bootloader, but the required xilisf library doesn not compile with serial_flash_family = 4 (Winbond) setting. The library version is 5.8, came with SDK 2017.2.
I'm getting thew following errors:
Description    Resource    Path    Location    Type
undefined reference to `XIsf_MicronFlashEnter4BAddMode'    bootloader.c    /rcom_srec_bootloader/src    line 319    C/C++ Problem
undefined reference to `XIsf_MicronFlashExit4BAddMode'    bootloader.c    /rcom_srec_bootloader/src    line 369    C/C++ Problem
'XISF_CMD_EXIT_4BYTE_ADDR_MODE' undeclared (first use in this function)    rcom_srec_bsp        line 1694    C/C++ Problem
'XISF_CMD_ENTER_4BYTE_ADDR_MODE' undeclared (first use in this function)    rcom_srec_bsp        line 1559    C/C++ Problem
Is there any workaround for this issue?
Ákos
