guinnesstrinker
SDK 2017.4: wrong names for base addr in xparameters.h
When exporting a Zynq-design with custom ip-cores to SDK the resulting .hdf looks like expected.
My design has an ip-core with more than one AXI-interfaces (S00_AXI, S01_AXI, S02_AXI).
In hw_platform system.hdf all baseaddresses etc. are correctly.
When generating a BSP in xparameters.h the names for the addresses of my ip-core do not include the AXI-interface like it was in earlier times (2015.4 for example).
As a result there is only one address available in xparameters.h
Details in 2015.4:
/* Definitions for peripheral FSBUS_0 */
#define XPAR_FSBUS_0_S00_AXI_BASEADDR 0x43C10000
#define XPAR_FSBUS_0_S00_AXI_HIGHADDR 0x43C1FFFF
#define XPAR_FSBUS_0_S01_AXI_BASEADDR 0x8AA20000
#define XPAR_FSBUS_0_S01_AXI_HIGHADDR 0x8AA2FFFF
#define XPAR_FSBUS_0_S02_AXI_BASEADDR 0x8AA30000
#define XPAR_FSBUS_0_S02_AXI_HIGHADDR 0x8AA3FFFF
Details in 2017.4:
#define XPAR_FSBUS_0_0 0x8AA20000
What is going wrong?
How can I fix it?
Is it a bug in SDK 2017.4?
guinnesstrinker
Same problem discussed in (Vivado 2017.2):
https://forums.xilinx.com/t5/Embedded-Processor-System-Design/Missing-Interfaces-in-xparameters-h/m-p/810096
Changing the name in properties (Message 4) is no solution. They are already different.
So I think it's a bug in Vivado/SDK 2017.x.
( or a hidden option that has to be activated ).
gmarinkovic
@guinnesstrinker
Can you try following:
1.) In your BSP set the drivers to generic
2.) Clean software project, hence the BSP is regenerated.
Do you see then the base addresses of your components?
Cheers
Goran
guinnesstrinker
All drivers of my own IPs are generic by default, because there are none (driver).
gmarinkovic
@guinnesstrinker
What a tricky problem... so your three components did pop up in the old Vivado 2015 but not in 2017. Let me guess you see the 3 components in the address view in Vivado and pressing F6 tells everything is ok? Then you compile and export the hardware to SDK sucessfully? Then you regenerated the BSP and you are pointing to the correct hardware? You have checked that in your hardware folder you see the new files an no old files?
Most of the times when Vivado tries to test my mental strength I delete all generated files manually and then regenerate the whole blob of data again keeping only the very basic set of files. In all cases I was fighting with the tool this was the only way to proceed with my work.
Cheers
Goran
guinnesstrinker
I started a new (empty) project/workspace in SDK. So there is no update-problem.
gmarinkovic
@guinnesstrinker
...some of the Vivado issues are best solved with a Guinness ;-)
Cheers
Goran
johnmcd
I expect that the separate address ranges for your ports were created using a device driver for your custom IP. Search your old design for a .mdd file. It's possible that your old sdk project pointed to a repository that contained your <customIP>/data/<customIP>.mdd. And within the data directory, there is probably also a <customIP>.tcl file which is responsible for assigning/defining what is added to the xparameters.h
If you choose the generic driver, then its .tcl in the sdk install directory (I.E. c:\xilinx\sdk\2017.4\data\embeddedsw\XilinxProcessorIPLib\drivers\generic_v2_0\data\generic.tcl) only assigns a single default base and high address.
Feel free to browse the .tcl for other drivers to get an idea of how cores with multiple ports and maybe interrupts, insert information into the xparameters.h.
stephenm
Is this a custom IP?
If so, then you can just update the driver (data-> driver_name.tcl) to include all the address spaces.
You can use the AR below for assistance here:
https://www.xilinx.com/support/answers/64980.html
guinnesstrinker
Sorry for the delay. I was out of office for some days.
When I created these ipcores years ago the wizzard also build a so called driver.
To stay at my "fsbus" example the content of
X:\ip_repo\fsbus_1.0\drivers\fsbus_v1_0\data\fsbus.tcl
was
proc generate {drv_handle} {
    xdefine_include_file $drv_handle "xparameters.h" "fsbus" "NUM_INSTANCES" "DEVICE_ID"  "C_S00_AXI_BASEADDR" "C_S00_AXI_HIGHADDR" "C_S01_AXI_BASEADDR" "C_S01_AXI_HIGHADDR" "C_S02_AXI_BASEADDR" "C_S02_AXI_HIGHADDR"
I changed it to the newer TCL syntax ("::hsi::utils::define_include_file ..").
Then I also added a local repository in SDK.
This was NEVER needed before. I always got the addresses into BSP with .hdf only!
As a result I get the missing names in xparameters.h, BUT wrong numbers:
/* Definitions for driver FSBUS */
#define XPAR_FSBUS_NUM_INSTANCES 1
#define XPAR_FSBUS_0_DEVICE_ID 0
#define XPAR_FSBUS_0_S00_AXI_BASEADDR 0xFFFFFFFF
#define XPAR_FSBUS_0_S00_AXI_HIGHADDR 0x00000000
#define XPAR_FSBUS_0_S01_AXI_BASEADDR 0xFFFFFFFF
#define XPAR_FSBUS_0_S01_AXI_HIGHADDR 0x00000000
#define XPAR_FSBUS_0_S02_AXI_BASEADDR 0xFFFFFFFF
#define XPAR_FSBUS_0_S02_AXI_HIGHADDR 0x00000000
What's wrong?
Remember: As you can see in screenshots above the correct addresses had always been provided through .hdf (system.hdf).
At our company there are different people working at HW- and SW-Design.
So it will cause much more work to transfer not only the .hdf, but also the corresponding ip_repo tree.
