Scholar ronnywebers
SDK 2018.2 - log4j:WARN No appenders could be found for logger (org.eclipse.jgit.util.FS). log4j:WARN Please initialize the log4j system properly
Eeach time I launch SDK from the command line, I get the following warning - not sure if / what it is harming, but can someone tell me what this means and how this can be fixed? Is some package / service missing?
10:59 $ xsdk
****** Xilinx Software Development Kit
****** SDK v2018.2 (64-bit)
  **** SW Build 2258646 on Thu Jun 14 20:02:38 MDT 2018
    ** Copyright 1986-2018 Xilinx, Inc. All Rights Reserved.
Launching SDK with command /opt/Xilinx/SDK/2018.2/eclipse/lnx64.o/eclipse -vmargs -Xms64m -Xmx4G -Dorg.eclipse.swt.internal.gtk.cairoGraphics=false &
~/zynq/2018_2/test/sdk
10:59 $
I'm running Ubuntu 16.04.3 on a Fusion VM :
zynqdev@zynqdev-VM:~$ lsb_release -a
No LSB modules are available.
Distributor ID:	Ubuntu
Description:	Ubuntu 16.04.3 LTS
Release:	16.04
Codename:	xenial
Re: SDK 2018.2 - log4j:WARN No appenders could be found for logger (org.eclipse.jgit.util.FS). log4j:WARN Please initialize the log4j system properly
Hi @ronnywebers
It seems to be something related to the host machine and eclipse modules... I guess that you already tried but you might want to check the error on non Xilinx related resources as the error seems to be much more generic.
i.e. https://stackoverflow.com/questions/1140358/how-to-initialize-log4j-properly
Ibai
