amassa
SDK BSP settings xilffs enable_mmc
I see enable_mmc was removed in 2016.4. How can this be added back to enable support in the BSP for the mmc driver?
ibaie
Hi @amassa,
According to the commit message where the option was removed the option is not longer required as the driver takes care of identifying the card type.
https://github.com/Xilinx/embeddedsw/commit/e3c17b43a17870e74f388d4cd381d5a6f06d12a6
Ibai
ibaie
Hi @amassa,
Ibai
