SDK Build Error
Hi,all
   When I compile,I get an error.YN3Z$0CTQ[]~I}J9JUM6D7B.jpg When I recreate the project,I got the same error.
I will be thankful for your answers.
Hi @zitengxiaxiang,
Could you show a screenshot of the console tab? It should give more information about the error.
It could be that you don't have enough memory on the target device.
Hi @zitengxiaxiang,
Thanks a lot.
according to your suggestion,I have solved this problem.
Hi @zitengxiaxiang,
As the issue is solved, could you mark on response as solution to close the thread?
