Observer mkaspare
SDK Generate Bitstream
I try to implement XAPP1026 on my SP605.
I open the sw folder as explained in the pdf. Than I want to download system.bit and the system_bd.bmm files. But the system.bit cant be found.
I cleaned and rebuild the project but the console says that for target "all" nothing is to do.
Does anyone know what I am doing wrong?
Thank you
Re: SDK Generate Bitstream
Can you confirm if the hw_platform folder has been imported in the step2 of XAPP1026?
--Hem
Observer mkaspare
Hello htsvn,
I have skipped step 2 because it is only for ZYNQ devices. But I have the SP605 with a Spartan 6.
So I import the folders in step 3. As you can see in my screenshot, the hardware folder is also imported.
Thanks for your support!
Scholar stephenm
you can just use the download.bit file in the xapp1026 zipped folder instead
It looks that we have to implment the design given in XAPP to generate the bitstream.
I just did a search of the *.bit in the complete XAPP and i could only find bitstreams in ready_to_download folder.
So at the moment you can try either to implement the design or use the files available in ready_to_download folder.
--Hem
Scholar stephenm
Import the download.bit into the hw_platform folder and use this instead. This will function just the same
Observer mkaspare
Hello stephenm,
it works with the download.bit. But I want erase the webserver so that I do not have to use the DDR Memory. I only want use FPGA internal memory, so I think I have to make changes in the project.
