SDK - No such port: Detecting COM Ports
I  am selecting my STDIO device as console in SDK, and i am using SP605 evaluation board.
When I run my developed application, I get this message - "No such port: Detecting COM Ports". What could be the possible causes to it?
Thanks and Regads,
Saransh
I get the same problem and my serial port can't receive correct data. Do anybody know the reason and share it? Thank you very much!!
Don't follow this if you are using ISE 14.7
It will trash your install. I failed to look at the dates...
The problem still exists for ISE 14.7 and the workaround seems to be using minicom or something
After some pain I found a solution to make the COM port work. please check it out here
