SDK : USING Xil_Out32,Xil_In32...........
Hi Everyone,
I am using Xil_Out and Xil_In Function to read and write the address,
But I dont really know " What is the return value ? like Hex , Oct , Dec , Bin ,
Who can know the answer,please tell me,
Thank you very much,
tuan,
Re: SDK : USING Xil_Out32,Xil_In32...........
Hi tuan94@ ,
There is no way to use xil_printf to directly display bianary (and I think printf in general). But you can always find a workaround. For example:
https://stackoverflow.com/questions/111928/is-there-a-printf-converter-to-print-in-binary-format
Florent
Hi tuan94@ ,
When you need more information on how a function is working, you usually check the definition of this function. Here it would be in:
https://github.com/Xilinx/embeddedsw/blob/fb647e6b4c00f5154eba52a88b948195b6f1dc2b/lib/bsp/standalone/src/common/xil_io.h
What is a returned value? An 32-bit unsigned word.
Is it bin, hex,...? This is really C basic, you might want to look back into your courses note. This is just a value in memory.
Florent
Hi ,
Thank you for answer,
I know that,
I just know about %x = Hex,%d= Decimal,
I can't use %b=binary,I want to convert it,
If you know that please tell me,
tuan,
Hi tuan94@ ,
What do you mean? When are you using it?
Florent
Thank your answer,
When I using:
Xil_In32(0x400000000);
xil_printf("%d",...); --> convert the value Decimal
xil_printf("%x",...); --> convert the value Hexan
I dont know how to convert  a value into Binary  ?
That is my question,
tuan,
I have a issue at link:
https://forums.xilinx.com/t5/Timing-Analysis/FPGA-ARTIX-7-Report-Timing-Summary-WNS-TNS/m-p/940855#M16101
Can I help me handle the problem,
tuan,
Hi tuan94@ ,
Florent
Thank your answer,
I will check it,
So I have a issue at Link:
Do you have some info or How to explain that for me ?
Thank you very much,I was waited for a long day,
tuan,
Hi tuan94@ ,
Timing is not my expertise so I do not want to reply on this.
Florent
I really thank for your help  very much,
Best wishes for you,
tuan,
Hi tuan94@ ,
If it is now working for you, could you kindly mark a reply as accepted solution to close the topic?
Florent
