06-10-2010 05:35 AM
I"m trying to run through a design to get Microblaze up on my Spartan 3AN dev board. The tutorial I'm using says to open the XML file to start using SDK. When I do that it comes up with an error, "Could not open the editor: Invalid Input: Must be IFileEditorInput."
-mike
06-23-2010 07:18 AM
Hey Mike,
Not quite sure which tutorial you are referring to, but have you checked out this one?
http://www.xilinx.com/support/documentation/sw_manuals/xilinx12_1/edk_ctt.pdf
-Felix
06-10-2010 10:43 AM
Using help I was able to click File-->New--->Xilinx Hardware Platform Specification which was able to import my hardware file. Now I'm not sure what to do because SDK isn't following the tutorial. The screen shot below is where I"M at. Anyone know the next step where I will have a "C/C++ Projects" tab to then start my software platform?
06-23-2010 07:18 AM
Hey Mike,
-Felix
08-23-2010 09:47 AM
Thanks a lot. The last post helped me out.
Names in Ver. 12 have changed comparing to ver. 11.
So, one must use an appropriate user guide in order to follow the correct flow.
