SDK Xilinx System Debugger and double Microblaze meaning
Hi all,
I've moved a Microblaze based design made originally with VIVADO 2016.1 in VIVADO 2017.4, all the imported process was fine, updating IP and so on.
I've exported the hardware design with bitstream and then run the SDK.
I'm able to debug with the GDB debugger and also with the Xilinx System Debugger (with this one in 2016.1 was not) but I don't know why or what is means into the Xilinx System Debugger about another Microblaze indication with no clock. In my design I've only one Microblaze, where came from the second one?
Thank!
Best regards
System debugger reads the MDM configuration register to determine how many instances of MB exist in the design. In your block design, there is only one MB, but the MDM seems to have 2 debug ports (MBDEBUG_0, 1). Due to this, MDM configuration register could be reporting 2 instances of MB. Can you try to get rid of the unused debug port in MDM, and generate a new bitstream?
You will not see this problem with GDB debugger in SDK, since it will always connect to only one MB at time, and your case it would connect to MB #0, since that what SDK sees in the HDF exported from Vivado
Here attached a pdf of the Block Design I'm unable to see two Microblaze in it... could you please guide me what I've to do now?
Also into the GDB debugger I can't see same issue...
Hi @sadanan,
thank you very much this solve the issue.
The debugger module was set for 2 Microblaze, reduced to 1 into the Block Design, then I've regenerated the bitstream.
After that I've exported the Hardware with bitstream and then start the SDK.
Now I've do the debug configuration and in this one I've to force program FPGA, without this we see two Microblaze, by checking this option the Xilinx System Debugger was able to show only one Microblaze.
to stop the simulation I use first "disconnect" and then "terminate and remove" is the correct sequence?
Here below my configuration for the Xilinx System Debugger.
from your perpective is all correct?
Thanks again!!
If you have programmed the new bitstream before launching the debug from SDK, then you wouldn't have to force 'program FPGA' in debug configuration.
