Visitor yinbinjun
SDK menory monitors BREAK down
SDK memory monitor is grayed out, Unable to add address
Re: SDK menory monitors BREAK down
Hi @yinbinjun,
The JTAG connection does not really enable access to the target, you need the debugger to be connected. In SDK terms you need to launch a debug session to be able to use the Memory window.
Ibai
Hi @yinbinjun
Could you provide mode details about your particular testcase? I mean, which release of the tool are you using? Is the debugger connected to the target when you do try to use the memory window?...
Ibai
Visitor yinbinjun
I useed vivoda 2017.4. every time when I use the memory window. the JTAG is connected to the FPGA(Zynq-702N). and I tried to delete the SDK folder and re-create the SDK project. The result is the same, the menory monitors can't be used
Hi @yinbinjun,
Ibai
