SDSoC cannot find linked libraries
I am very new to using SDSoC & petalinux
I am trying to compile a project that uses pthread and X11.
I managed to build a petalinux project including libx11-dev & a few other dependencies, and i built the sdk & sysroot.
I now have my sysroot set to
/home/joris/avnet-digilent-zedboard-2018.2/images/linux/sdk/sysroots/cortexa9hf-neon-xilinx-linux-gnueabi/
I have X11 & pthread listed in "libraries" and my sysroot's /lib and /usr/lib included in the library search path. I also have the sysroot's /usr/include folder in the include for sds++ & sdscc
if I include those folders in the search path, then i get an error saying that /lib/libpthread.so.o and /usr/lib/libpthread_nonshared.a cannot be found (Those are both correctly in the sysroot's /lib & /usr/lib folder):
Link application ELF file
Using built-in specs.
COLLECT_GCC=arm-linux-gnueabihf-g++
COLLECT_LTO_WRAPPER=/opt/Xilinx/SDK/2018.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/../libexec/gcc/arm-linux-gnueabihf/7.2.1/lto-wrapper
Target: arm-linux-gnueabihf
Configured with: /proj/esdt_sdk/gnu_abe/ABE/builds/lin/arm/arm-linux/snapshots//gcc-linaro-7.2-2017.11-rc1/configure SHELL=/bin/sh --with-bugurl=https://bugs.linaro.org --with-mpc=/proj/esdt_sdk/gnu_abe/ABE/builds/lin/arm/arm-linux/builds/destdir/x86_64-unknown-linux-gnu --with-mpfr=/proj/esdt_sdk/gnu_abe/ABE/builds/lin/arm/arm-linux/builds/destdir/x86_64-unknown-linux-gnu --with-gmp=/proj/esdt_sdk/gnu_abe/ABE/builds/lin/arm/arm-linux/builds/destdir/x86_64-unknown-linux-gnu --with-gnu-as --with-gnu-ld --disable-libstdcxx-pch --disable-libmudflap --with-cloog=no --with-ppl=no --with-isl=no --disable-nls --enable-c99 --enable-gnu-indirect-function --disable-multilib --with-tune=cortex-a9 --with-arch=armv7-a --with-fpu=vfpv3-d16 --with-float=hard --with-mode=arm --disable-multilib --enable-multiarch CFLAGS=-O2 CXXFLAGS=-O2 --disable-silent-rules --enable-libquadmath --enable-libg2c --enable-symvers=gnu --enable-libstdcxx-pch --enable-libssp --disable-libmudflap --enable-checking=release --enable-cheaders=c_global --enable-poison-system-directories --enable-clocale=generic --enable-shared --enable-threads=posix --disable-multilib --enable-c99 --without-local-prefix --enable-lto --disable-bootstrap --with-linker-hash-style=gnu --with-ppl=no --with-cloog=no --without-isl --enable-nls --enable-__cxa_atexit --with-build-sysroot=/proj/esdt_sdk/gnu_abe/ABE/builds/lin/arm/arm-linux/builds/destdir/x86_64-unknown-linux-gnu/arm-linux-gnueabihf/libc --enable-plugins --enable-linker-build-id --enable-long-long --enable-shared --with-sysroot=/proj/esdt_sdk/gnu_abe/ABE/builds/lin/arm/arm-linux/builds/destdir/x86_64-unknown-linux-gnu/arm-linux-gnueabihf/libc --enable-languages=c,c++,lto --enable-checking=yes --disable-bootstrap --with-bugurl=https://bugs.linaro.org --build=x86_64-unknown-linux-gnu --host=x86_64-unknown-linux-gnu --target=arm-linux-gnueabihf --prefix=/proj/esdt_sdk/gnu_abe/ABE/builds/lin/arm/arm-linux/builds/destdir/x86_64-unknown-linux-gnu
Thread model: posix
gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11-rc1)
COMPILER_PATH=/opt/Xilinx/SDK/2018.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/../libexec/gcc/arm-linux-gnueabihf/7.2.1/:/opt/Xilinx/SDK/2018.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/../libexec/gcc/arm-linux-gnueabihf/:/opt/Xilinx/SDK/2018.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/../libexec/gcc/:/opt/Xilinx/SDK/2018.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/../lib/gcc/arm-linux-gnueabihf/7.2.1/../../../../arm-linux-gnueabihf/bin/
LIBRARY_PATH=/opt/Xilinx/SDK/2018.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/../lib/gcc/arm-linux-gnueabihf/7.2.1/:/opt/Xilinx/SDK/2018.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/../lib/gcc/arm-linux-gnueabihf/:/opt/Xilinx/SDK/2018.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/../lib/gcc/:/opt/Xilinx/SDK/2018.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/../lib/gcc/arm-linux-gnueabihf/7.2.1/../../../../arm-linux-gnueabihf/lib/:/opt/Xilinx/SDK/2018.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/../arm-linux-gnueabihf/libc/lib/:/opt/Xilinx/SDK/2018.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/../arm-linux-gnueabihf/libc/usr/lib/
COLLECT_GCC_OPTIONS='-L/home/joris/avnet-digilent-zedboard-2018.2/images/linux/sdk/sysroots/cortexa9hf-neon-xilinx-linux-gnueabi/lib' '-L/home/joris/avnet-digilent-zedboard-2018.2/images/linux/sdk/sysroots/cortexa9hf-neon-xilinx-linux-gnueabi/usr/lib' '-v' '-L/opt/Xilinx/SDx/2018.2/target/aarch32-linux/lib' '-L/home/joris/workspace2/test_sys/Debug/_sds/swstubs' '-o' '/home/joris/workspace2/test_sys/Debug/_sds/swstubs/test_sys.elf' '-shared-libgcc' '-march=armv7-a' '-mtune=cortex-a9' '-mfloat-abi=hard' '-mfpu=vfpv3-d16' '-marm' '-mtls-dialect=gnu'
 /opt/Xilinx/SDK/2018.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/../libexec/gcc/arm-linux-gnueabihf/7.2.1/collect2 -plugin /opt/Xilinx/SDK/2018.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/../libexec/gcc/arm-linux-gnueabihf/7.2.1/liblto_plugin.so -plugin-opt=/opt/Xilinx/SDK/2018.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/../libexec/gcc/arm-linux-gnueabihf/7.2.1/lto-wrapper -plugin-opt=-fresolution=/tmp/ccUDGtDl.res --sysroot=/opt/Xilinx/SDK/2018.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/../arm-linux-gnueabihf/libc --build-id --eh-frame-hdr --hash-style=gnu -dynamic-linker /lib/ld-linux-armhf.so.3 -X -m armelf_linux_eabi -o /home/joris/workspace2/test_sys/Debug/_sds/swstubs/test_sys.elf -L/home/joris/avnet-digilent-zedboard-2018.2/images/linux/sdk/sysroots/cortexa9hf-neon-xilinx-linux-gnueabi/lib -L/home/joris/avnet-digilent-zedboard-2018.2/images/linux/sdk/sysroots/cortexa9hf-neon-xilinx-linux-gnueabi/usr/lib -L/opt/Xilinx/SDx/2018.2/target/aarch32-linux/lib -L/home/joris/workspace2/test_sys/Debug/_sds/swstubs -L/opt/Xilinx/SDK/2018.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/../lib/gcc/arm-linux-gnueabihf/7.2.1 -L/opt/Xilinx/SDK/2018.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/../lib/gcc/arm-linux-gnueabihf -L/opt/Xilinx/SDK/2018.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/../lib/gcc -L/opt/Xilinx/SDK/2018.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/../lib/gcc/arm-linux-gnueabihf/7.2.1/../../../../arm-linux-gnueabihf/lib -L/opt/Xilinx/SDK/2018.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/../arm-linux-gnueabihf/libc/lib -L/opt/Xilinx/SDK/2018.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/../arm-linux-gnueabihf/libc/usr/lib /home/joris/workspace2/test_sys/Debug/src/test.o /home/joris/workspace2/test_sys/Debug/_sds/swstubs/portinfo.o -lX11 -lpthread --start-group --end-group --start-group -lpthread -lsds_lib -lxlnk_stub --end-group
/opt/Xilinx/SDK/2018.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/../lib/gcc/arm-linux-gnueabihf/7.2.1/../../../../arm-linux-gnueabihf/bin/ld: cannot find /lib/libpthread.so.0
/opt/Xilinx/SDK/2018.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/../lib/gcc/arm-linux-gnueabihf/7.2.1/../../../../arm-linux-gnueabihf/bin/ld: cannot find /usr/lib/libpthread_nonshared.a
collect2: error: ld returned 1 exit status
ERROR: [SdsCompiler 83-5019] Exiting sds++ : Error when calling 'arm-linux-gnueabihf-g++     /home/joris/workspace2/test_sys/Debug/src/test.o /home/joris/workspace2/test_sys/Debug/_sds/swstubs/portinfo.o -L/home/joris/avnet-digilent-zedboard-2018.2/images/linux/sdk/sysroots/cortexa9hf-neon-xilinx-linux-gnueabi/lib -L/home/joris/avnet-digilent-zedboard-2018.2/images/linux/sdk/sysroots/cortexa9hf-neon-xilinx-linux-gnueabi/usr/lib -v -lX11 -lpthread   -L /opt/Xilinx/SDx/2018.2/target/aarch32-linux/lib -L/home/joris/workspace2/test_sys/Debug/_sds/swstubs -Wl,--start-group  -Wl,--end-group -Wl,--start-group    -lpthread -lsds_lib -lxlnk_stub  -Wl,--end-group -o /home/joris/workspace2/test_sys/Debug/_sds/swstubs/test_sys.elf'
sds++ log file saved as /home/joris/workspace2/test_sys/Debug/_sds/reports/sds.log
ERROR: [SdsCompiler 83-5004] Build failed
makefile:45: recipe for target 'test_sys.elf' failed
make: *** [test_sys.elf] Error 1
If I don't include the /lib & /usr/lib in the library search path then i get an error saying cannot find -lX11
Thread model: posix
COLLECT_GCC_OPTIONS='-v' '-L/opt/Xilinx/SDx/2018.2/target/aarch32-linux/lib' '-L/home/joris/workspace2/test_sys/Debug/_sds/swstubs' '-o' '/home/joris/workspace2/test_sys/Debug/_sds/swstubs/test_sys.elf' '-shared-libgcc' '-march=armv7-a' '-mtune=cortex-a9' '-mfloat-abi=hard' '-mfpu=vfpv3-d16' '-marm' '-mtls-dialect=gnu'
 /opt/Xilinx/SDK/2018.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/../libexec/gcc/arm-linux-gnueabihf/7.2.1/collect2 -plugin /opt/Xilinx/SDK/2018.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/../libexec/gcc/arm-linux-gnueabihf/7.2.1/liblto_plugin.so -plugin-opt=/opt/Xilinx/SDK/2018.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/../libexec/gcc/arm-linux-gnueabihf/7.2.1/lto-wrapper -plugin-opt=-fresolution=/tmp/ccmdNS6v.res -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lc -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lgcc --sysroot=/opt/Xilinx/SDK/2018.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/../arm-linux-gnueabihf/libc --build-id --eh-frame-hdr --hash-style=gnu -dynamic-linker /lib/ld-linux-armhf.so.3 -X -m armelf_linux_eabi -o /home/joris/workspace2/test_sys/Debug/_sds/swstubs/test_sys.elf /opt/Xilinx/SDK/2018.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/../arm-linux-gnueabihf/libc/usr/lib/crt1.o /opt/Xilinx/SDK/2018.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/../arm-linux-gnueabihf/libc/usr/lib/crti.o /opt/Xilinx/SDK/2018.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/../lib/gcc/arm-linux-gnueabihf/7.2.1/crtbegin.o -L/opt/Xilinx/SDx/2018.2/target/aarch32-linux/lib -L/home/joris/workspace2/test_sys/Debug/_sds/swstubs -L/opt/Xilinx/SDK/2018.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/../lib/gcc/arm-linux-gnueabihf/7.2.1 -L/opt/Xilinx/SDK/2018.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/../lib/gcc/arm-linux-gnueabihf -L/opt/Xilinx/SDK/2018.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/../lib/gcc -L/opt/Xilinx/SDK/2018.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/../lib/gcc/arm-linux-gnueabihf/7.2.1/../../../../arm-linux-gnueabihf/lib -L/opt/Xilinx/SDK/2018.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/../arm-linux-gnueabihf/libc/lib -L/opt/Xilinx/SDK/2018.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/../arm-linux-gnueabihf/libc/usr/lib /home/joris/workspace2/test_sys/Debug/src/test.o /home/joris/workspace2/test_sys/Debug/_sds/swstubs/portinfo.o -lX11 -lpthread --start-group --end-group --start-group -lpthread -lsds_lib -lxlnk_stub --end-group -lstdc++ -lm -lgcc_s -lgcc -lc -lgcc_s -lgcc /opt/Xilinx/SDK/2018.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/../lib/gcc/arm-linux-gnueabihf/7.2.1/crtend.o /opt/Xilinx/SDK/2018.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/../arm-linux-gnueabihf/libc/usr/lib/crtn.o
/opt/Xilinx/SDK/2018.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/../lib/gcc/arm-linux-gnueabihf/7.2.1/../../../../arm-linux-gnueabihf/bin/ld: cannot find -lX11
ERROR: [SdsCompiler 83-5019] Exiting sds++ : Error when calling 'arm-linux-gnueabihf-g++     /home/joris/workspace2/test_sys/Debug/src/test.o /home/joris/workspace2/test_sys/Debug/_sds/swstubs/portinfo.o -v -lX11 -lpthread   -L /opt/Xilinx/SDx/2018.2/target/aarch32-linux/lib -L/home/joris/workspace2/test_sys/Debug/_sds/swstubs -Wl,--start-group  -Wl,--end-group -Wl,--start-group    -lpthread -lsds_lib -lxlnk_stub  -Wl,--end-group -o /home/joris/workspace2/test_sys/Debug/_sds/swstubs/test_sys.elf'
I believe the problem is that pthread is included in "LIBRARY_PATH" and something gets messed up when it finds it twice, but libX11 is not in the standard "LIBRARY_PATH", and therefore isn't found when the sysroot's libs aren't included.
Alright i found the issue finally,
Have to go into the sds++ linker settings, under miscellaneous set --sysroot="/home/joris/avnet-digilent-zedboard-2018.2/images/linux/sdk/sysroots/cortexa9hf-neon-xilinx-linux-gnueabi"
