Spidev in QEMU
Hello, I am trying to get a spidev device emulated in QEMU. I have it enabled in my device tree but it does not appear in the /dev/ folder on my emulated Zynq. Here is my device tree
/dts-v1/;
    #address-cells = <0x1>;
     #size-cells = <0x1>;
     compatible = "xlnx,zynq-7000";
      model = "petaproject";
      amba {
          compatible = "simple-bus";
          interrupt-parent = <0x3>;
          ranges;
           spi@e0006000 {
               compatible = "cdns,spi-r1p6";
               reg = <0xe0007000 0x1000>;
               status = "okay";
               interrupts = <0x0 0x31 0x4>;
               clocks = <0x1 0x1a 0x1 0x23>;
               clock-names = "ref_clk", "pclk";
               #size-cells = <0x0>;
              num-cs = <0x4>;
              is-decoded-cs = <0x0>;
             flash@0 {
                 compatible = "sst25wf080";
                 reg = <0x1>;
                 spi-max-frequency = <0xf4240>;
                partition@test {
                   label = "spi-flash";
                   reg = <0x0 0x100000>;
            spidev@0x02 {
                 compatible = "spidev";
                  spi-max-frequency = <0x124f80>;
                  reg = <0x0>;
Can QEMU emulate spidev?
Re: Spidev in QEMU
have you enabled this in the kernel?
