vohaid
Thread execution in xilkernel
when using xilkernel, threads are created using the "sys_thread_new" command.  In some app (xapp1026 for example) the thread creation are as follows:
sys_thread_new(network_thread, NULL, DEFAULT_THREAD_PRIO);  // create a thread called network_thread
sys_thread_new(tftpserver_application_thread, 0, DEFAULT_THREAD_PRIO);  // create a thread called tftpserver_application
sys_thread_new(web_application_thread, 0, DEFAULT_THREAD_PRIO);  // create a thread called web_application
In this case, all the threads have a priority level of "DEFAULT_THREAD_PRIO".  How does xilkernel know which thread to execute first or which task gets to interrupt another?
Where is this "DEFAULT_THREAD_PRIO" get defined?
HV
