Observer dsatyamu
Time.h functions not compiling on Xilinx SDK 2017.4 and launching on ZCU102
I'm trying to see how long it takes my FPGA to add two numbers, so I used the time.h library but it's not compiling.
Also, is this the best way to benchmark the performance of the FPGA or is there a better way?
 * main.c
 *  Created on: Jul 16, 2018
 *      Author: me
#include "xparameters.h"
#include "xil_io.h"
#include "xbasic_types.h"
#include "time.h"
int main(){
    u32 adder_out;
    time_t start,end;
    //int t;
    xil_printf("Start of IP Adder 8 bit test\n\n\r");
    //start=clock();
    Xil_Out32(XPAR_MYIPADDER8BIT_0_S00_AXI_BASEADDR, 0x00000301);
    adder_out = Xil_In32(XPAR_MYIPADDER8BIT_0_S00_AXI_BASEADDR+4);
    xil_printf("A=1, B=3, S=%d\n\r", adder_out);
    Xil_Out32(XPAR_MYIPADDER8BIT_0_S00_AXI_BASEADDR, 0x0000FF13);
    xil_printf("A=19 in DEC, B=255 in DEC, S=%d\n\r", adder_out);
    //end=clock();
    //t=(end-start)/CLOCKS_PER_SEC;
    //xil_printf("Time is %d\n\n\r", t);
    return 0;
I am seeing the following error:
makefile:36: recipe for target 'myAdderSW.elf' failed
collect2: error: ld returned 1 exit status
make: *** [myAdderSW.elf] Error 1
Please let me know what I need to change to get the timestamp while running the application using Serial UART?
Scholar hbucher
Re: Time.h functions not compiling on Xilinx SDK 2017.4 and launching on ZCU102
There is no GLIBC on standalone mode. You have to read the cycles from either an internal counter or an external component.
If you're on a Zynq, use something like this (not tested)
#include <stdio.h>
#include "platform.h"
#include "xtime_l.h"
int main()
XTime tStart, tEnd;
init_platform();
XTime_GetTime(&tStart);
print("Hello World\n\r");
XTime_GetTime(&tEnd);
print("Output took %llu clock cycles.\n", (tEnd - tStart));
print("Output took %.2f us.\n", 1.0 * (tEnd - tStart) / (COUNTS_PER_SECOND/1000000));
return 0;
On other platforms like microblaze, you have to add and use the Timer IP.
Scholar hbucher
#include <stdio.h>
int main()
XTime tStart, tEnd;
init_platform();
return 0;
Observer dsatyamu
Although, counts per second did not work, the code worked after I hardcoded the counts per seconds information.
Scholar hbucher
@dsatyamu You can get that info from xparameters.h I believe.
That said I myself use clock cycles not nanoseconds for performance measurements.
