Type fatal error: lwip/err.h: No such file or directory
        I'm getting this error when i try to generate lwIP server Application project. I m using SDK 14.7 Tool.
       I have just gone through the other similar issue, and varied that lwIP lib is include or not. And I can see that the lib is icluded in BSP.
     Can anyone please help me what should I do
    This error I'm getting
I tried to create a new SDK workspace using your hardware platform (Ethernet_hw_platform), but i encountered the following error:
From the above error, it looks like you have not enabled the ethernetlite interrupts in your hardware project. Please note that this is a must when trying to use the lwip stack.
You may want to refer to the hardware project as mentioned in xapp1026
http://www.xilinx.com/support/documentation/application_notes/xapp1026.pdf
Can you please check your hardware project if the interrupts are connected properly?
Can you attach the SDK workspace?
Hello ,
             Please find Workspace attached
Thank u for ur time and help.That was the problem.I connected timer interrupt and just left ethernetlite interrupt unseen thinking that it will be connected by default.
Now i will try creating .mfs file.Hopefully, it should not give any problem.
