UCF file syntax
I'm trying to find the commands and syntax for the UCF file, but the information is either in plain view and I'm stupid, or it's well hidden somewhere and I can't find it.  Of course, I can copy bits of other files, but it'd be nicer if I could understand what I am doing as I did it!  I'm using EDK 9.1.
Can anybody help, please?
Cheers,
Trevor
Re: UCF file syntax
The syntax description locates in  \Xilinx\doc\usenglish\books\docs\cgd,
 try to find it in your computer
Re: UCF file syntax
You can also find the Constraints Guide on-line:
Though I suspect it will generally be more convenient to refer to the copy included in your ISE install, as mentioned above by jatxl3.
Cheers,
bt
Re: UCF file syntax
I should have mentioned an easier way to find this locally (assuming Windows platform)
Start -> Programs -> Xilinx ISE 9.1i -> Documentation -> Software Manuals
Click on "Design Entry" then "Constraints Guide" (2nd item down the list)
To get back to the main page, simply click on "Software Manuals" in the Acrobat bookmarks pane.
There is a lot of other good information here too.
Re: UCF file syntax
Thanks very much.  Part of the problem is that I am using a Linux install of the ISE and EDK, and because that doesn't set up any menus it's hard to determine what's what in the directory tree.
Cheers,
Trevor.
Re: UCF file syntax
Trevor,
That makes sense. In that case you may want to have a quick way (bookmark, shortcut, soft-link, etc.) to access the "manuals.pdf" file as that is the main Xilinx ISE "Software Manuals" document and includes embedded links to the other documents.
You should find this under your xilinx installation path under /doc/usenglish/books (assuming Linux has a similar directory structure to Windows, which in my case is %XILINX%\doc\usenglish\books)
Good luck,
bt
