jrhtech
Unable to modify BSP integer value in vitis 2020
I'm trying to modify the tick rate for FreeRTOS but non of the integer params can be modified.   bools give you a choice as does the uart, but unlike the SDK can can't modify the int params.  Any ideas?
thanks,
jeff
ibaie
Hi @jrhtech
Could you elaborate bit more on this? I mean, do you mean that you are not able to modify integer type values in the BSP configuration menu for FreeRTOS?
Ibai
jrhtech
  Yes, that's the problem. If I click on the 'Modify BSP Settings' under my Board Support Package, select freertos10_xilinx and try to modify any of the values that have a type of integer I cannot change the value.  For example, in the xSDK I change the tick_rate to 1000 by clicking on the value column.
  Now I had to script a process that generates the BSP then applies a patch to that BSP to get the tick_rate I want.   I patch the FreeRTOSConfig.h in the src directory but if I patch the mss then I can see the modified tick_rate in the menu(but still can't change it).
thanks,
jeff
stephenm
The FreeRTOSConfig.h is dynamically created when you create the BSP:
https://github.com/Xilinx/embeddedsw/blob/master/ThirdParty/bsp/freertos10_xilinx/data/freertos10_xilinx.tcl#L625
This uses the settings in the MSS file
https://github.com/Xilinx/embeddedsw/blob/master/ThirdParty/bsp/freertos10_xilinx/data/freertos10_xilinx.mld#L51
Let me guess your OS..... Ubuntu? This is a known issue.
You WA of changing the MSS file should work, even if it is frustrating
jrhtech
Yes, Ubuntu 16.
The release notes don't mention this. Is there another place where known issues are tracked?
Also, I just discovered the 'bsp config' command. Since I generate my projects from scripts before I use the GUI then I could use this command to set params instead of patching.
thanks,
jeff
