Updatemem (Vivado 2019.2.1) accepts only elf (not mem)
I'm using updatemem (on Linux) to populate two memory-spaces for two CPUs (LM32).
The first core I'm programming with an ELF file, the second using a MEM file. Then I get this error:
ERROR: [Common 17-69] Command failed: File /.../clb_v2_dom.mem is not a elf file. Incorrect file extension.
Indeed it is not an ELF file. But why does it not accept a .mem file, according to the documentation it should.
Command:
updatemem -meminfo /.../fpga.mmi
-data /.../wrc.elf -proc lm32_wrpc_memory
-data /.../clb_v2_dom.mem -proc lm32_2nd_memory
-bit /.../fpga.bit -out clbv2dom.bit -force
(Replace long path names with ...)
Any help regarding this would be most helpful.
Cheers,
Vincent
Re: Updatemem (Vivado 2019.2.1) accepts only elf (not mem)
Hi @vvanbeveren
The sintax seems to be OK and I would expect it to work, but I'm wondering if it might be a limitation or bug using different data types (ELF and MEM) in a single updatemem command. As a quick test you could split the command in two steps to check if it works:
updatemem -meminfo /.../fpga.mmi  -data /.../wrc.elf -proc lm32_wrpc_memory  -bit /.../fpga.bit -out step1.bit -force
updatemem -meminfo /.../fpga.mmi -data /.../clb_v2_dom.mem -proc lm32_2nd_memory  -bit step1.bit -out clbv2dom.bit -force
Ibai
Hi @vvanbeveren
Ibai
I see the same (with test 1):
I used the TCL script here to test:
proc test_updatemem {test} {
 if {$test == 1} {
  exec updatemem -debug -force -meminfo design_1_wrapper.mmi -data hello.elf -data test.mem -proc design_1_i/microblaze_0 -proc design_1_i/microblaze_0 -bit design_1_wrapper.bit -out download.bit > dump.txt
 if {$test == 2} {
  exec updatemem -debug -force -meminfo design_1_wrapper.mmi -data test.mem -proc design_1_i/microblaze_0 -bit design_1_wrapper.bit -out download.bit > dump.txt
 if {$test == 3} {
  exec updatemem -debug -force -meminfo design_1_wrapper.mmi -data hello.elf -proc design_1_i/microblaze_0 -bit design_1_wrapper.bit -out download.bit > dump.txt
 if {$test == 4} {
  exec updatemem -meminfo design_1_wrapper.mmi -data hello.elf -proc design_1_i/microblaze_0 -bit design_1_wrapper.bit -out download_int.bit
  exec updatemem -debug -force -meminfo design_1_wrapper.mmi -data test.mem -proc design_1_i/microblaze_0 -bit download_int.bit -out download.bit > dump.txt
This is a bug. I will file a CR
As a workaround, as Ibai suggested you can run updatemem twice (test 4 above):
Hi Ibaie,
Sorry, I clicked on the wrong post to accept as a solution. Not sure how to revert. But indeed running it twice works.
Cheers,
Vincent
edit: found it. But thanks stephenm for your insight and tests and reporting the bug.
