fostercl1
Updating driver version when multiple instances are defined causes BSP regeneration to fail
We have several products that have multiple instances of IIC, DMA, etc.
We keep the system.mss file tracked in our VCS, so the driver versions are retained.
When we update to a newer version, this is done through SDK's Board Support Settings drop down. I can update the Axi IIC driver version here from 3.4 to 3.5:
When that is done, all four instances of the axi_iic driver get updated in the UI:
However, the regen system.mss file only updates one of the versions:
And the regnerate BSP fails due to multiple driver versions:
The system.mss file should correctly reflect that all drivers have changed.
As a result, I have to reopen the dialog multiple times to change the driver version. After doing this several times, the BSP can correctly be regenerated.
stephenm
What flow are you using?
  • Change the MSS (with all the drivers rev'ed) in the BSP in the GUI
  • Then do a clean in the SDK
Or are you doing this from the command line:
  • updatemss
  • regenbsp
fostercl1
  • updatemss
  • regenbsp
We are changing the BSP driver versions in the GUI. Screenshots are attached in my original post.  The GUI seems to update, but those changes don't properly get set in the MSS.
