Using SDK 14.6 with XPS 14.4
Hi all,
I want to ask that is it possible to use SDK 14.6 with XPS 14.4??
Umair
Re: Using SDK 14.6 with XPS 14.4
Yes this should be possible:
1. Generate the Bitstream in XPS 14.4
2. Open SDK 14.6 and set a workspace.
3. File > New > Project > Xilinx > Hardware Platform Specification file to open the New Hardware Project dialog box.
4. For the "Target Hardware Specification" field, browse to the system.xml file of your XPS project. You will find this file in the "_xps" folder of your hardware (XPS) project. Selecting the file will automatically populate the Project Name field.
5. Click Finish. Close the welcome screen if it is open.
Is there any specific reason that you want to do this?
You might have to use the drivers in SDK 14.6 that are compatible with older version of IP's(EDK 14.4)
--Hem
Yes i want to save large amount of data from console and i think there is memory dump functionality exist in SDK but from 14.6 so that is why i want to use. Secondly i have build old my HDL in XPS 14.4 and i dont want to upgrage my old IPs :)
Umair
