Scholar muravin
VIVADO 2014.1 - SDK in headless mode, cannot build
Hello All,
This is my first attempt to run the SDK 2014.1 in a headless mode as I understand appguru is a no-go with VIVADO 2014.1, Linux x64.
What am I missing here? A Linux package? Yet another bug in VIVADO or Eclipse?
I have created an xml file as an XSDK input script and it succesfully builds a) the project, b) the bsp and c) the app (Empty Appl.)
That is, I have followed:
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_1/SDK_Doc/concepts/sdk_c_headless_mode.htm
As a result, after running " xsdk -script temp.xml --workspace temp_workspace "  I am having the following directory structure:
/temp_workspace/
/temp_workspace/eclipse_bsp
/temp_workspace/eclipse_app
/temp_workspace/eclipse_app/src
Furthermore, I copied the c/h files we are using for our software to be compiled into a Microblaze, and I am trying to build the application. I always get an error.
For example, if I build the application, after I run:
$ECLIPSE -vm $VM -nosplash -application org.eclipse.cdt.managedbuilder.core.headlessbuild -build $APPNAME -data $WSPACE-vmargs -Dorg.eclipse.cdt.core.console=org.eclipse.cdt.core.systemConsole
I get an error in a pop-up Window (see below)
JVM terminated. Exit code=1
/opt/Xilinx/SDK/2014.1/tps/lnx64/jre/bin/java
-XX:MaxPermSize=256m
-Xms64m
-Xmx512m
-jar /opt/Xilinx/SDK/2014.1/eclipse/lnx64.o//plugins/org.eclipse.equinox.launcher_1.3.0.v20120522-1813.jar
-os linux
-ws gtk
-arch x86_64
-launcher /opt/Xilinx/SDK/2014.1/eclipse/lnx64.o/eclipse
-name Eclipse
--launcher.library /opt/Xilinx/SDK/2014.1/eclipse/lnx64.o//plugins/org.eclipse.equinox.launcher.gtk.linux.x86_64_1.1.200.v20120913-144807/eclipse_1502.so
-startup /opt/Xilinx/SDK/2014.1/eclipse/lnx64.o//plugins/org.eclipse.equinox.launcher_1.3.0.v20120522-1813.jar
--launcher.overrideVmargs
-exitdata 267d00a4
-build eclipse_app
-data temp_workspace-vmargs
-vm /opt/Xilinx/SDK/2014.1/tps/lnx64/jre/bin/java
-vmargs
-Xms64m
-Xmx512m
BR
Vlad
Vladislav Muravin
Scholar stephenm
Re: VIVADO 2014.1 - SDK in headless mode, cannot build
Attached is a headless mode script tat you can use as a reference. tjis will build a BSP, FSBL, and a hello world app. you can see the command used in my_SDKproj.xml
Scholar muravin
Steve,
Thanks for your response.
I jumped straight to 2014.2 once it came out, and just now finished bypassing new issues introduced by the latest version.
Your script is indifferent from mine but I am on Linux x64, and I wonder now, since the XML file no longer exported, how do I run the headless mode with VIVADO 2014.2?
SDK 2014.2 help offers no examples as related to 2014.2, the help is dated for 2014.1; can you please help out with that? Should I add hwh file now instead of xml?
Thanks!
Vlad
Vladislav Muravin
