stgateizo
Voyager
Voyager
Vitis 2020.1 => Cannot debug on driver level
Dear colleagues,
In SDK I was able to debug on driver level, when I compiled the bsp with the extra compiler flags "-O0 -g3" (turning optimization off and set debug level to 3).
With Vitis it does not seem to work anymore. I did the settings as depicted below (I hope I did it the right way), but when I want to debug the driver source code of the Video Phy Controller for the HDMI_TX design, the pointer is jumping around like crazy.
In the console, I can see that the driver source files are compiled with "-O0 -g3".
Any idea how I can overcome this issue? I have to debug on driver level (Video Phy Controller), otherwise I cannot find the root cause of my problem...
stgateizo
stgateizo
Voyager
Voyager
Hello Krishna,
today I have deleted the Vitis project and rebuild it completely from scratch. After I have rebuild the project, the problem still appeared. But after I have updated the Extra Compiler Flags "-O0 -g3" in the BSP, I'm now able to debug also on driver level es expected.
But this means, that something went wrong in the past. Well I often make a copy of a Vivado project, including laso the Vitis project for making a backup copy, or for trying things out. But it seems that this can lead to problems?
For now i think this issue is solved, but I often loose control over Vitis, especially when I update the blockdiagram in Vivado, and I have to update the hardware platform in Vitis. I often have the feeling that it does not work properly afterwards.
One example, as I changed the memory size for the Microblaze in the address editor of Vivado, the size change was not visible in the linker script, even after deleting and regenerating the linker script. How can this be?
Normally I do the followign steps when I cahnge something in Vivado:
1) Validate Blockdesign in Vivado
2) Generate Blockdesign in Vivado
3) Crate HDL-Wrapper (only if the IO-interfaces have changed)
4) Generate Bitstream
5) Export Hardware incl. Bitstream
6) Update Hardware Specification in Vitis
7) Genearte Linker Script in Vitis (only when the Microblaze Memory Size or location has changed)
Clean and Build the complete project in Vitis
These are more or less the steps which I used in SDK...
Did I forgett somtehing?
Best regards
stgateizo
stephenm
Are you on ubuntu? This is a known issue.
To workaround this, you can update the makefile directly:
stgateizo
Voyager
Voyager
Hello stephenm
thank you for this advice. Well I'm using Windows 10 64bit not Linux. As you can see below, the MakeFile already contains the ExtraComiplerFlags -O0 -g3, only the order is different, but I think this does not have any influence.
I also can see in the console that the driver sources will be compiled with -O0 -g3.
So this cannot be the problem. Any further ideas?
stgateizo
florentw
Hi @stgateizo
Can you keep only "EXTRA_COMPILER_FLAGS=-g"? (no other option for EXTRA COMPILER FLAG)
Florent
stephenm
Ok, the WA I provided would only work for the BSP. You would need to update the makefile for your driver
stgateizo
Voyager
Voyager
Hi Florent,
I removed "-O0 -g3" in the Extra Compiler Flags and just leave "-g" in. I cleaned the complete project and re-build it again, but the problem is not gone.
Kind regards
stephenm
You need to pass these to the driver makefile.
stgateizo
Voyager
Voyager
Hi stephenm,
I want to debug in the source code of the file xvphy_hdmi.c, which is a driver file, and therewith part of the BSP.
So yes, I want to set the Extra Compiler Flags for the BSP, and have set them as depicted in the previous psot. As far as I can see the source file for the vphy is compiled with "-Wextra -O0 -g3" as you can see below:
"Compiling vphy"
"Running Make libs in HDMI_TX1_mb_mblaze/libsrc/vtc_v8_2/src"
make -C HDMI_TX1_mb_mblaze/libsrc/vtc_v8_2/src -s libs "SHELL=CMD" "COMPILER=mb-gcc" "ASSEMBLER=mb-as" "ARCHIVER=mb-ar" "COMPI
LER_FLAGS= -O2 -c -mcpu=v11.0 -mlittle-endian -mxl-soft-mul" "EXTRA_COMPILER_FLAGS=-g -ffunction-sections -fdata-sections -Wal
l -Wextra -O0 -g3"
By the way I can no longer see your first post, where you mada some suggestions...
What else do you want to do?
stgateizo
stgateizo
Voyager
Voyager
Hello stephenm,
plaese take a look to one of the previous posts, where I have put in a screenshot of my make file. The Option "-O0 -g3" is already in, and no I don't use Linux.
stgateizo
stephenm
Can you do an objdump -r execuable.elf | grep <function name>
stgateizo
Voyager
Voyager
Hi stephenm,
here is a screenshot, so that you can see that I refer to the make file of the BSP (I hope the picture quality is good enough...):
What does Florent mean with (there is no other option than -g for the Extra Complier Settings) ?
Is it no longer supported in Vitis?
Steffen
stephenm
Also, I meant make the changes directly to the driver makefile:
COMPILER=
ARCHIVER=
CP=cp
COMPILER_FLAGS=
LIB=libxil.a
CC_FLAGS = $(COMPILER_FLAGS)
ECC_FLAGS = $(EXTRA_COMPILER_FLAGS)
Then verify in the objdump to make sure it was applied
stgateizo
Voyager
Voyager
Hi stpehenm,
I have tried the following command in the XSCT console:
objdump -r T:/V2_2/vitis/HDMI_TX1/Debug/HDMI_TX1.elf | grep XVphy_SetHdmiTxParam
xsct% child process exited abnormally
I assume I made somthing wrong?
stephenm
you would use the relevant objdump for your processor. For example, for the cortex a53; aarch64-none-elf-objdump
florentw
Hi @stgateizo
I used to just use the option "-g" for the Extra Compiler setting to debug inside the video drivers.
In the platfrom in Vitis, select Modify BSP Settings:
Then in the extra compiler flags settings I used only the option -g:
And rebuild the platform
Florent
stgateizo
Voyager
Voyager
Hi stpehenm,
now I have changed the make file of the driver as depicted below. The driver function which I want to debug is named "XVphy_HdmiCpllParam()". This function is located in the file "xvphy_hdmi.c", which belongs to the driver "vphy_v1_10". I hope I have modified the correct make file now?
By the way I have modified all make files in the same way, which belongs to the HDMI and VPHY driver.
After the modification, I have cleaned and rebuild the whole project, but the result is as before. The pointer is still jumping back and forth in a crazy manner as soon as I enter the function "XVphy_HdmiCpllParam()"...
stgateizo
stgateizo
Voyager
Voyager
Hi Florent,
also your suggestion was not successful. See settings below:
Before, I have cleaned and rebuild the whole project, I have reset the extra compiler flags in the vphy_v1_10 driver make file...
stgateizo
Voyager
Voyager
One question,
can we exclude that this issue is maybe caused by a lack of memory for the microblaze?
The memory for instruction and data is 256KByte in size. The compiler tells me that he needs 235864Bytes (see below), which is close to the maximum.
Well I know that I use some code which reserves memory by using the malloc function. So maybe there is more memory required then printed below?
Can we exclude this issue?
'Invoking: MicroBlaze Print Size'
mb-size HDMI_TX1.elf |tee "HDMI_TX1.elf.size"
text data bss dec hex filename
224272 3512 8080 235864 39958 HDMI_TX1.elf
'Finished building: HDMI_TX1.elf.size'
stgateizo
Voyager
Voyager
There is one interresting fact. The function XVphy_HdmiCpllParam() is in the same driver source file as the parent function XVphy_SetHdmiTxParam(). The strange thing is, that I can properly step through the parent function XVphy_SetHdmiTxParam(), until the function XVphy_HdmiCpllParam() is entered.
So this is mayb an indicator that the instruction point runs really crazy, since the MB is running out of memory.
Is there an easy way to check this?
stephenm
How big is your stack and heap?
The ELF size should grow if you enable debug. Do you see this?
Also, generate the map file and this will tell you how things are mapped:
https://www.xilinx.com/support/answers/23025.html
stgateizo
Voyager
Voyager
Hi stephenm,
lscript.ld says:
heap size = 0x400
stack size = 0x800
Active build debug => ELF-Size  = 235864 Bytes
Active build release => ELF-Size = 207568 Bytes
I tried to follow the following instructions to generate the map-file:
In SDK:
  1. Right-click the software application project and select Properties.
  2. Select the C/C++ Build in the left pane.
  3. With the Tools tab brought forward, select Miscellaneous under Linker.
  4. In the Linker Flags, add -Wl,-Map -Wl,"C:\<fullpath>\<name>.map"
  5. Click OK.
I got stuck at point 3. There is no Tool tab named Linker with the option to set Miscellaneous:
stephenm
How much you assign in malloc? you could try increase these two here and try again
stgateizo
Voyager
Voyager
Hi stephenm
I tried the following steps:
In Vivado:
1) Increased memory size from 256KB to 512KB in address editor and saved block diagram
2) Generate Output Products of block diagram
3) Generate Bitstream
5) Exported Hardware + bit stream
In Vitis:
7) Cleaned platform, application projects, system project
Build the whole stuff
Unfortunately there is no improvement...
One question, under SDK there existed the possiblity to regenerate the linker script. I'm missing this function in Vitis?
Will the linker script be automatically updated, when I change the memory size for the Microblaze?
stgateizo
stephenm
The linker should be automatically generated. Is this not the case. You might be better creating the workspace from scratch
stgateizo
Voyager
Voyager
Hi stephenm,
Set Stack Size to 0x4000 and Heap Size to 0x8000 in lscript.ld (use now 512KB memory), and cleaned & rebuild all the stuff.
Problem still exists...
I spent now the whole day, just to find a solution how I can debug the driver file, with a negative result.
Actually I just wanted to fix a bug a today, instead I'm struggling with the new Tools...
This is something which I defenitely must not tell my boss...
I'm really frustrated.
stgateizo
stgateizo
Voyager
Voyager
Hello Krishna,
Best regards
stgateizo
stephenm
This is good that your initial issue is resolved. Can you mark this s solved to help others please?
The Linker is built using the metadata extracted from the XSA using HSI.
Can you clean the platform and rebuild. Does the Linker file get updated as expected?
stgateizo
Voyager
Voyager
Hi stepehnm,
no, the linker script is not updated when I do the following steps:
1) Under Project => Clean, I clicked on the Clean Button with the following settings:
2) Checked the compile date of the lscript.ld, but it was not modified. The compile date is from this morning when I recreated the Vitis project from scratch.
Should the "Last modification" date be updated with a clean/build all ?
regards
stegateizo
stgateizo
Voyager
Voyager
Hi stephenm,
but I can confirm, that the linker script is changing when I click on "Generate Linker Script". I think this behavior is as expected ?
regards
stgateizo
stephenm
Yes, I just checked. the linker will not be automatically updated. However, can you make sure all the other BSP components where updated
