Vitis hangs reading XSA
Hi, I am unable to create a new application project on vitis 2020.1. Vitis seems to hang forever reading the hardware specification file (.XSA) when creating a new project:
1) select "create application project" from the vitis welcome page, which start a wizard.
2) after the wizard welcome page the user is asked to select an hardware specification file (.XSA). This is the first input from the user in this wizard procedure.
3) select any .xsa (in this case, as shown in the picture, I choose a .xsa included in the vitis installation for simple reproduction of this bug).
4) after clicking "next" I get a warning message on the top of the window ("Invalid application project name. Project name must be specified") and the wizard hangs on "Reading hardware specification". The wizard can only be terminated by killing the process.
Any help?
I was facing the same issue for the longest time, but I managed to find a solution. Checking the IDE.log that got created in the vitis workspace folder, I found an error talking about xlsclients
19:52:01 ERROR : (XSDB Server)which: no xlsclients in ...
After installing the package which had that command (xorg-xlsclients), it worked without issue!
Can you share the XSA file please?
sure, I had to compress it to upload here.
I tried this real quick on my end without issue:
What OS are you using? Are you on a network drive?
Fedora 31, running on the physical drive. I will try in another system when I can.
Tried on another Fedora installation and with archlinux. It works with Fedora but have the same problem with the arch installation.
Even if they are not supported systems, I will try to investigate the issue when I have time.
That was it, I missed that logfile. Thanks @connertenn!
