Vivado 2014.1 Hello World
I was able to see the output of the Hello World application through UART on my custom ZYNQ board in ISE 14.7. However since I switch to VIVADO 2014.1, the PuTTY console does not show anything. I just generate the bitstream and export the hardware to SDK like I did in ISE. Then I choose the Hello World app from the templates, program the FPGA and launch the app. The app starts and terminates successfully like it should. However in PuTTY I can not get to see anything. Do I have to make any other things like starting the hw_server for example?
Re: Vivado 2014.1 Hello World
Can you check if the procedure mentioned in page 31 and 32 works?
http://www.xilinx.com/support/documentation/sw_manuals_j/xilinx2014_1/ug940-vivado-tutorial-embedded-design.pdf
--Hem
--Hem
Thanks for your reply. Following it, I checked my Run Configurations and saw that the connection was disabled there. After I connected it to COM7 and did the same on PuTTY side, it worked.
Again the same issue occured. I just restarted my PC. When I try the very same design which showed me "Hello World", I get nothing to see in the console. I did not change anything in the design and SDK project settings. Is this some kind of a bug in Vivado 2014.1? Has anybody faced a similar issue? I try to fix this since today morning and it is a bit frustrating.
