Observer fen1xl
[Vivado 2017.2] Problem with *.mmi file
I can't get a *.mmi file.
I have the block design.
There is the Address Editor.
When I try to create *.mmi file from Tcl Console.
write_mem_info D:/out.mmi
I get this.
CRITICAL WARNING: [Memdata 28-122] data2mem failed with a parsing error. Check the bmm file or the bmm_info_* properties on the BRAM components. The design BRAM components initialization strings have not been updated.
CRITICAL WARNING: [Memdata 28-147] Could not complete BRAM data initialization for processor. Please check to ensure any BMM and ELF files in the design have correct proper scoping specified. Design will proceed but BRAM initialization strings will not be populated with contents of the ELF file.
ERROR: [Common 17-69] Command failed: Failed to create the: D:/out.mmi The design contains processors. Verify processor instances and connectivity.
The goal is to get access to any microblaze's memory from any microblaze.
Re: [Vivado 2017.2] Problem with *.mmi file
can you try with the attached script?
source this from the tcl console, and use the command write_mem_info_int test.mmi for example
You will need to implment the design first
Observer brainiac
Hello! I have the same problem...
After synthesizing and implementing design, I opened design by
open_run impl_1
Then I sourced the script:
source D:/workspace/write_mem_info.tcl
Then I tryed to get mmi file
write_mem_info_int D:/test.mmi
And I get
no files matched glob patterns "type -f D:/test.mmi"
I tryed write_mem_info -force D:/test.mmi
ERROR: [Common 17-69] Command failed: Failed to create the: D:/test.mmi The design contains processors. Verify processor instances and connectivity.
Version of Vivado is 2017.3
Observer brainiac
I run write_mem_info_int test.mmi and script executed and file is empty
How to determine that everything is ok? I have project with 30% utilization of BRAM...
Visitor daniel2016
I have the same problem under both 2016.2 and 2018.1. Is there any solution on this?
In the OP's issue. This is most likely due to the fact that there are 3 microblaze_0 (ie with the same name). This is likely confusing the tool.
@daniel2016. For your issue, can you describe your system (maybe a screenshot too?)
Visitor daniel2016
Thanks. We don't use microblaze and neither use the SoC name into the design. We use Microzed board (loaded with Zynq 7020).
Hey Guys,
I have created a wiki article on the memdata flow in Vivado:
http://www.wiki.xilinx.com/Understanding+MEMDATA+flow+and+how+to+manually+create+MMI+file
Hopefully, this will help some users here
