Participant leoeltipo
Vivado SDK Git source files only
I am trying to integrate Git version control in my FPGA projects. I already managed to create the minimum set of files that allow me to build the Vivado project. From there, I can implement the design and create the hardware definition. Finally, I can launch the SDK to have a working complete environment.
Now what I want to do is simple. Add source files (.h and .c) into a new clean SDK application project. I do not want to commit any platform related file, only .h and .c. I have a git remote repository I can clone with the .h and .c files. All I want is to use these files to build my application. The unique option I found is importing the files, but that will copy the files locally and any changes won't be detected as they will be on a different location from the original git repository.
Is this (simple) thing possible at all? Again, I do not want to version control the whole project, only source files.
Thank you in advance,
Leo
Re: Vivado SDK Git source files only
Hi @leoeltipo
You can use the import menu and use the advanced tab to select "Create links in workspace", that would give just link the file without copying it into the workspace.
Ibai
Hi @leoeltipo
Ibai
