ank_mistry
Vivado SDK Programming Failed
I'm tring to program Artix 7 board for Ethernet Iwip appliciation. But using Vivado SDK 2015.2 programming fails saying download.bit file is not found. The Console window gives following message
cmd /C updatemem -force -meminfo \
E:/*/project_5/project_5.sdk2/design_1_wrapper_hw_platform_0/design_1_wrapper.mmi -bit \
E:/*/project_5/project_5.sdk2/design_1_wrapper_hw_platform_0/design_1_wrapper.bit -data \
C:/Xilinx/Vivado/SDK/2015.2/data/embeddedsw/lib/microblaze/mb_bootloop_le.elf -proc \
/microblaze_0 -out \
E:/*/project_5/project_5.sdk2/design_1_wrapper_hw_platform_0/download.bit
****** updatemem v2015.2 (64-bit)
  **** SW Build 1266856 on Fri Jun 26 16:35:25 MDT 2015
    ** Copyright 1986-2015 Xilinx, Inc. All Rights Reserved.
source C:/Xilinx/Vivado/SDK/2015.2/scripts/updatemem/main.tcl -notrace
ERROR: [Updatemem 57-85] Invalid processor specification of: /microblaze_0. The known processors are: design_1_i/microblaze_0
How can I solve this issue ? Please suggest.
Anonymous
Not applicable
This is using updatemem. One of updatemems parameters is the -proc. If you open the MMI file and view the Instpath you will see what this should be set to (from your error message this is design_1_i/microblaze_0). However, in the command line being used, this is set to /microblaze_0.
So, the easiest way to fix this is to open the MMI and change the instpath to "microblaze_0" and re-running
Anonymous
Not applicable
ank_mistry
Hi ,
It did sove the problem. But instead of "microblaze_0", I edit it like "/microblaze_0".
So, next uestion which comes is everytime I need to make this changes? If so then it something where Tool needs a update. Because anytime .hdf file is changed or when you program FPGA board .mmi will be auto updated.
Thank you for help
Anonymous
Not applicable
Yes, this looks like a bug in the HWH file that is exported to SDK that has the incorrect instpath.
This instpath is used in the Program FPGA GUI.
There are two ways to workaround it; modify the MMI, or modify the updatemem command line, and call the updatemem manually with the correct -proc option (in your case this should be design_1_i/microblaze_0)
ank_mistry
Ok. I tried both way and things are working.
Thank you for help
