Vivafo problem in exporting hardware to SDK
I am using VIvado 2014.1,
I have design a hardware and also generated bitstream, but when I am trying to export this hardware to sdk,
it is stuck at 0%. Even after several hours process stay as it is.
Does anyone has suggestions on it?
Re: Vivafo problem in exporting hardware to SDK
Hey @ashish7724,
Maybe try a more recent version of Vivado?
Best,
Herbert
Hi @ashish7724,
I like this suggestion:
If you really want to stick with a really old version of vivado, you can try to export the hw to another path. You maybe don't have some rights preventing vivado to generate the file
