What is the meaning of WARNING:ConstraintSystem:135
Version 10.1.03
I created a very simple EDK project (to figure out another problem I'm having with EDK) and I get pages and pages of warnings that look like this:
WARNING:ConstraintSystem:135 - Constraint <INST: UniqueName:
   /system/EXPANDED/system/ppc405_0/ppc405_0\/IPLB0_PLBv46_Adapter_i\/adapter_cs
   _FSM_FFd7-In11 TNM = FFS:ppc405_0_WRAPPER>: No instances of type FFS were
   found under block
   "ppc405_0/ppc405_0/IPLB0_PLBv46_Adapter_i/adapter_cs_FSM_FFd7-In11"
   (type=LUT4_D).
Why are these generated? The BSB glued together the PPC core and and PLB.
Of course I can't find any help on this message. Can someone shed some light?
Even if this is a thread started about two years ago, someone might have the same question so here is the answer
http://www.xilinx.com/support/answers/31758.htm
