mii-chan
Where is xil_printf function for microblaze ?
I'm looking for the xil_printf function for microblaze spartan cpu (with SDK 9.2.01) in standalane 1.00.a (because I want modify it for my application).
Where is the file xil_printf.c ?
I am not sure about microblaze but  under ppc you can find them here:
$EDK_PROJECT / ppc405_0 / libsrc / standalone* / xil_printf.c
ppc405_0 stands for $cpu$ver_$instance - so in your case you should have a look on something like mb*_0 for single cpu.
Greetings, Mariusz.
Mariusz Grad.
s1130014
I can find xil_printf.c in the directory for PPC but I cannot find xil_printf.c, too.
I use SDK 12.1 in ISE12.1 system edition.
And, character corruption is happened in terminal.
If you solved the problem already, please teach me the solution.
c1engr
Has anyone found the location of this function yet?
payamfoug1
It is a very old post, but I still looking for a proper answer to this question if anybody can help me.
It is just a curiosity question. As xil_printf() function works without any problem. However, I prefer to understand how it works in SDK14.7. and asking if somebody can shed a little bit of light on it. There is a xil_printf.c implementations for all platform folders, but no file for microblaze. As there is a xil_printf.h header file, where the compiler find and compile the function implementation? Is it using one of other .c files on other platforms folders? If yes, which one, and how we can trace properly such things.
