Why the source file (.c) can use the function in another source file without include the file?
I just find a question which confused me. In the template project: lwIP Echo Server, Inside 'src' folder, there are "main.c" and "echo.c" files. In "main.c", the main function use some functions inside "echo.c" file such as "int start_application()"
However, I did not find any commands inside "main.c" to include the "echo.c" file and there is no corresponding header file for "echo.c". But why the functions can be still used inside the main function?
Hope somebody can help me to understand this, thanks advance!
Re: Why the source file (.c) can use the function in another source file without include the file?
This is a C programming concept and not related to the environment.
First things first ..The use of a header file is to include the function prototypes! So that implicite decleration is avoided..Now the function prototype int start_application() is include in the main file itself! U will find it just below the include statements.
That is why there is no echo.h because all the functions defined in echo.c file which are called in the main are declated as prototypes in the main file..
And as far as including echo.c goes there is no such thing! when u build a project with all the source files it complies everything ..So as long as u have the function prototype and the defination they can be access any function defined in any file.. Its easier to use header files because you dont have to declare the prototypes every time rather you can just include the corresponding file containing the prototypes.
Hope this helps
Anybody can help?
The way u stated ur problem,that makes me confused too..BTW go with xapp1026 for LWIP
I am sorry my statement confused you, Let me state it again and may be more clear.
There are "main.c" and "echo.c" two source files in LWIP project. In "main.c", main function call functions inside "echo.c" file such as "int start_application()"
However, I did not find "main.c" include the "echo.c" file and there is no corresponding header file for "echo.c". So I can not understand why the functions can be still called inside "main.c"?
BTW, what is xapp 1026 you mentioned?
Thanks very much.
If two .c files use the same project directory then their functions can be  used as such way..
xapp1026 is xilinx application note available as .pdf format....just make Google search with xapp1026,u shall get that pdf
Thanks, that makes sense. Is this rule general fro all C development in any IDE or just for IDE like Xilinx SDK?
Thanks again.
Hi, I checked the xapp 1026 file. Inside Lwip, there is an application "TCP RX Throughput Test and TCP TX Throughput Test". I just wonder is this application can use Ethernet to transmit and receive data?
Hope this helps
Thanks, ur explanation is very clear. But if I want to do implicite decleration, the source code which has these function prototypes must be inside the same project folder, right?
Otherwise, the compiler can not know where the functions are.
I am not sure I understood your question correctly. But implicite decleration of functions are not allowed in C. U have to declare the functions explicitly.
Now I think I got it. The function declaration like "int start_application()" is explicitly declaration. If there is no corresponding header file for "echo.c" and I do not declare the function "int start_application()", but I call it in "main.c". implicite declaration will happen.
Yes that is EXACTLY what happens.
It seems in SDK, if you have implicite declaration,it will report warning instead of error.
Yes it does report it as a warning as strictly speaking its not an error. But u can change the option in the build settings to promote all warnings to errors. That way you will solve all warnings before finalizing the program. But this can be tedious so be warned.
Got it, thanks!
Okay , good. Please close the thread by accepting what ever post was in direct relation to your original question as the solution. Would help others in the future to go to the solution more quickly .
regards
Arvind
Thanks, Arvind. I will.
