Visitor liangyu323
Windows 7 SDK fatal error: xparameters_ps.h: No such file or directory
OS: windows 7
I usded PlanAhead to export SDK and I imported an exist project.
But I got this error: fatal error: xparameters_ps.h: No such file or directory
I have done this method, but it didn't work.
http://forums.xilinx.com/t5/Embedded-Development-Tools/Linux-SDK-fatal-error-xparameters-ps-h-No-such-file-or-directory/m-p/399141#M29695
Best,
Lenny
Re: Windows 7 SDK fatal error: xparameters_ps.h: No such file or directory
Which version of SDK are you using here? If it is 2014.1 i would recommend you to create a new BSP.
--Hem
Visitor liangyu323
Hi Hem,
I use ise14.7.and it includes SDK.
Lenny
Visitor liangyu323
Hi Hem,
I want to run TRD14.2.
I try to create a new BSP, but I don't know how to use the exist project if I create a new project.
but when I create a new project and change the new src to exist src, I got a new problem:
'XDCFG_MCTRL_RFIFO_FLUSH_MASK' undeclared (first use in this function) pcap.c /test1/src line 485 C/C++ Problem
So I don't know how to create a new BSP to use exist project.
Please give some details.
Best,
Lenny
Scholar sampatd
The reason you get these errors is because TRD 14.2 was created long time back (probably 2012), and there have been multiple revisions done to the fsbl code since then (for e.g., pcap.c where you see the error is part of the FSBL software).
For example, see the FSBL changelogs:
http://www.xilinx.com/support/answers/56356.html
http://www.xilinx.com/support/answers/56508.html
You will need to create a fresh workspace in 14.7 or use 14.2 tool to use the TRD files.
