Visitor luqman1
Write_bmm
Running
write_bmm xyz.bmm
gives error
ERROR: [Memdata 28-96] Could not find a BMM_INFO_DESIGN property in the design. Could not generate the merged BMM file: xyz.bmm
ERROR: [Common 17-69] Command failed: Failed to create a merged bmm file.
Where is the property BMM_INFO_DESIGN described in documentation?
Re: Write_bmm
Why are you running write_bmm? Are you writing out the file for taking into SDK?
In which case you should just be using the export to SDK option. In that case if you see this error, that is a bug..
Please explain what you are trying to do..
Duth
Visitor luqman1
Re: Write_bmm
I want to create bmm file so that a tcl script can use it to update internal rom with internal processor software. We are not using SDK. I have generated bmm file manually. There are 4 different roms (2kx128). How can I automatically generate bmm file and backannotate it if placement change is changes during compile?
Thank you
Mirza
Re: Write_bmm
Are you creating this design in XPS or IPI or is it hand generated?
Right now all we support is IPI and XPS generated flows for writing out a back-annnotated BMM file.
Duth
Visitor currently
Re: Write_bmm
luqman1,
I had the same problem.  There is an answer here http://www.xilinx.com/support/answers/53064.html that describes a workaround.  I have been successfully using this approach.  Hope it helps you also
Visitor luqman1
Re: Write_bmm
Thank you very much. I will try it today.
Visitor luqman1
Re: Write_bmm
I thought that in the backannotated version LOC will be replaced by PLACED. But see both LOC and PLACED. Is that OK?
Scholar stephenm
Re: Write_bmm
The write_bmm, or the Vivado tool will only generate a BMM file for all the memory mapped memory controller in your XPS/IPI project.
If you are generating your memory outside this flow (ie through coregen, ip in Vivado, no IPI), then the tools will not auto generate a BMM file. The write_bmm will not write this either.
The AR that was mentioned was created by me, this just simply created a backannotated BMM file by manually searching the routed design for the BRAM locations using the instance path. Again, this will only work if you are using a memory mapped memory controller in the XPS or IPI design.
If you are using a memory outside this flow, then the BMM will need to be created Manually by the user:
http://www.xilinx.com/support/answers/46945.htm
Visitor sinclairrf
Re: Write_bmm
I reviewed the listed documentation and couldn't find anything that helped.  I'm using my own micro controller (https://github.com/sinclairrf/SSBCC) and needed a procedure to generate the BMM for the micro controller instruction memory.
What I wound up doing was the following:
1.  Identify the Block RAMs in the implemented design by entering the following TCL command after place and route:
foreach a [get_cells -hierarchical -filter { LOC =~ "RAMB*" }] { puts $a; report_property [get_cells $a] LOC; }
This lists the memory names and their locations.
2.  Look through the output to identify the name for your memory.
3.  Use the following TCL command to write the memory locations you care about to your Vivado log file:
set memName {uc/inst/s_PC_reg_rep};
set memLoc [report_property -return_string [get_cells $memName] LOC];
puts "MYBMMINFO: $memName [lindex $memLoc 7]";
4.  Write an AWK script to find these entries and to generate the BMM file.
