betontalpfa
XIntc_Initialize hangs at restart
I want to share my experience with XIntc_Initialize
Use case:
  1. I usually relaunch the software (without reloading the complete FPGA) during development time
  2. I have a watchdog that restarts the software in case of an (unhandled) error.
Problem:
In case of the restart the XIntc_Initialize() function hangs frequently.
betontalpfa
The solution is to reset the interrupt controller before initializing it. There is no reset function in the handlers (if there is, please inform me) so I collected all of the writable registers and set back the reset values of them.
void reset_irq_ctrl(u32 base){
    // This interrupt disable needed by the restart of the SW.
	XIntc_Out32(base+ XIN_ISR_OFFSET, 0);
	XIntc_Out32(base+ XIN_IPR_OFFSET, 0);
	XIntc_Out32(base+ XIN_IER_OFFSET, 0);
	XIntc_Out32(base+ XIN_IAR_OFFSET, 0);
	XIntc_Out32(base+ XIN_SIE_OFFSET, 0);
	XIntc_Out32(base+ XIN_CIE_OFFSET, 0);
	XIntc_Out32(base+ XIN_MER_OFFSET, 0);
	XIntc_Out32(base+ XIN_IMR_OFFSET, 0);
Xilinx employees, please add this reset into the handler functions of the interrupt controller.
I use:
  • Win10
  • Vivado 2017.4
betontalpfa
I use:
  • Win10
  • Vivado 2017.4
