XPS does not launch external PDF viewer
After installing the latest Xilinx Platform Studio, if I rmb on a IP block and select 'show PDF', nothing happens.
I am using Gentoo Linux and on a SuSE Linux computer next to mine it works fine.
I know I could search and view the PDF files manually from the Xilinx directory but I'd rather 'fix' XPS instead. So how does XPS try to launch the PDF?
Tags (3)
Re: XPS does not launch external PDF viewer
I knew of a known issue which is mentioned here.
http://www.xilinx.com/support/answers/31279.htm
Check if this is applicable to you.
Thnx
Thnx
I have not installed acroread but XPS never showed me an error when it couldn't find the executable.
In case others run into something similar, I'll post my 'fix' as well.
I prefer 'okular' from KDE 4 over acroread so I added a file called 'acroread' to '/usr/bin' and inserted the following:
#!/bin/bash
export LD_LIBRARY_PATH=""
/usr/bin/okular $1 $2 $3 $4 $5
Newbie noodle758
thx for the solution here. I met the same problem and worked on it for couple of days.Before reading this post ,I think it is not possiable to launch my c# pdf viewer.  Everything is OK now.
Newbie abigail111
HI THERE
I have tried your pdf viewer in xps, and i still can not launch it.What's wrong with it?
Should i change a pdf viewer?Or is there any other suggetion?Any suggestion will be
highly appreciated.
Visitor arronlee
Hi, noodle758.
I am also testing about the related PDF viewing projects these days. Do you have any ideas about it? Or any good suggestion? Thanks in advance.
Best regards,
Arron
If you use a script to launch another program, do not forget to make it executable by running 'chmod +x' (assuming you use linux)
