XSCT: "PROJECT_LOCATION" variable, does it exist ?
Hello
Upon launching XSCT, it opens in the .../AppData/Roaming/Xilinx/Vivado directory.
Does exist some variable that allows to jump into current project ?
Re: XSCT: "PROJECT_LOCATION" variable, does it exist ?
Hi @pavel_47
Please use $cd command to change the directory and navigate to your directory.
Best Regards,
Nutan
Best Regards,
Nutan
Hi @pavel_47
Best Regards,
Nutan
Best Regards,
Nutan
