Visitor cokezero
XSCT timeout when starting SDK
Migrating our Artix 7 project from ISE to Vivado 2016 under Linux (Fedora 21).
We're trying to create/build a microblaze project from the command line (eventually via makefile).
But in fundamental testing of xsct, I get the error that xsct is unable to connect with the SDK for simple SDK commands such as  "toolchain"
I've installed Xvfb
via bash terminal:
$. /opt/Xilinx/SDK/2016.1/settings64.sh
$Xvfb :1&
$export DISPLAY=:1
$xsct
****** Xilinx Software Commandline Tool (XSCT) v2016.1
   **** Build date : Apr 8 2016-16:07:20
     ** Copyright 1986-2016 Xilinx, Inc. All Rights Reserved.
xsct% setws ./myworkspace
xsct% toolchain
Starting SDK.  This could take few seconds...
[60 seconds later]
Starting SDK. This could take few seconds... timeout while establishing a connection with SDK
xsct%
If, instead, I run xsdk independently it launches the SDK gui in x-windows, but we highly desire this to be command line only (TCL scripting).
The created ./myworkspace/SDK.log is blank.
Thanks in advance.
Visitor cokezero
Re: XSCT timeout when starting SDK
I believe I have resolved my issue.
/etc/hosts did not have "localhost" on 127.0.0.1
instead it only had "mymachine.localdomain mymachine" aliasing 127.0.0.1
I added "localhost localhost.localdomain localhost4 localhost4.localdomain4" to 127.0.0.1
    127.0.0.1    localhost localhost.localdomain localhost4 localhost4.localdomain4 mymachine.localdomain mymachine
Discrete xsct commands and tcl scripting now works.
check these documents
http://www.xilinx.com/support/answers/64200.html
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_1/SDK_Doc/SDK_concepts/sdk_c_batch_mode.html
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_2/ug1208-xsct-reference-guide.pdf
http://www.xilinx.com/video/hardware/how-to-develop-and-debug-using-xsct.html
http://www.xilinx.com/support/answers/65094.html
Thanks and Regards
Balkrishan
There is an issue with SSH scripting in 2016.1.  This will be fixed in 2016.3.
Visitor cokezero
@glena
Hi.
Can you clarify? I'm running this commands in and I get timeout error, is this the problem you meant?
tsotne@viineripirukas ~ $ source /cad/x_16/SDK/2016.1/settings64.sh
tsotne@viineripirukas ~ $ xsdk -batch
xsct%
xsct%
xsct% setws workspace
..# set variables
xsct% createhw -name hw_0 -hwspec $dir/design_1_wrapper.hdf
xsct%
xsct% Starting SDK. This could take few seconds...
xsct%
xsct%
and can i fix that by changing this number  "variable sdk_launch_timeout 60000" in file /cad/x_16/SDK/2016.1/scripts/xsdb/xsdb/xsdb.tcl ? (on line 1629)
namespace eval ::xsdb {
    variable version 0.1
    variable curchan {}
    variable curtarget ""
    variable xsdb_src_dir
    variable command_metadata {}
    variable bptable [dict create]
    variable bpfmttable [dict create]
    variable streamtable [dict create]
    variable streamreader_bufs [dict create]
    variable memmaptable [dict create]
    variable memmap_ctxs [dict create]
    variable designtable [dict create]
    variable swdesignmaps [dict create]
    variable info_messages 0
    variable force_mem_accesses 0
    variable profile_config [dict create]
    variable expr_fmt_dict [dict create]
    dict set expr_fmt_dict 1 [dict create 1 cu 2 su 4 iu 8 wu]
    dict set expr_fmt_dict 4 [dict create 1 cu 2 su 4 iu 8 wu]
    dict set expr_fmt_dict 2 [dict create 1 c 2 s 4 i 8 w]
    dict set expr_fmt_dict 7 [dict create 1 c 2 s 4 i 8 w]
    dict set expr_fmt_dict 3 [dict create 4 r 8 q]
    proc checkbool {b} {
    if { ![string is boolean -strict $b] } {
        error "expected boolean but got \"$b\" instead"
Thank you
@note: this might sound weird but i have to request the change of that file on server - where i have no edit rights.. otherwise i would have tried it myself...
p.s. it prints this error exactly after 60sec. or maybe there is other bug and that is the reason it might take 'forever' to launch?
Visitor cokezero
I had tried adding timeout to over an hour with no success. No amount of additional timeout waiting would have resolved the fundamental networking issue my machine had. If you are still waiting 60+ seconds to start the SDK, but it eventually starts, perhaps you need to write a new question to the forum and/or involve your server admin.
The launch timeout can be increased thru configparams command. However, increasing the timeout doesn't help always and is only needed when SDK is slow to start (for example, if you're launching it from a network drive).
Are you able to start SDK manually from the same terminal and using the same workspace? If so, can you set the log level to trace (Window -> Preferences -> Xilinx SDK -> Log Information Level) from the SDK GUI and then reuse the same workspace from XSCT, and send the log. You may also want to delete ~/.Xilinx, before starting XSCT/SDK
Hi @sadanan
yes i can launch sdk manually and i did change it to trace.
but however when xsct does not write anything into that log file, even though i specified same directory as workspace.
also, i was not able to somehow specify the log file for xsct, no option for that.
p.s. in general sdk launch takes 5-10 seconds.
What else can be done?
Visitor cokezero
If your /etc/hosts file has "localhost" on the line reading 127.0.0.1 and you are still having problems, then you have a different issue. This issue is marked solved and cannot have 2 solutions marked. I suggest you create a new topic to get more help from others than use this old topic.
yes, but anyways, i fixed the problem, i had to set:
setenv SWT_GTK3 0
probably its specific only for me because of reasons, so not important to open another topic
Newbie eaaltonen
setenv SWT_GTK3 0
No, this seems to be required on Ubuntu 16.04 (at least on the default Unity desktop).
Visitor thomas144
I found that typing this:
export SWT_GTK3=0
just before "petalinux-build" fixed it for me.
