XSDB script for programming only PS with PL already programmed
Hi all,
I have and XSDB script to programming my PL with a bitstream and then download the executable like that:
connect
targets
targets 2
rst -processor
fpga -f C:/VM_Exchange/design_1_wrapper.bit
source C:/VM_Exchange/ps7_init.tcl
ps7_init
ps7_post_config
dow C:/VM_Exchange/smp01.x
con
I want to save some time, the bitstream will always be the same. How can I do a script to only download the executable file while FPGA bitstream keeps. I try with this, but doesn't work:
connect
targets
targets 2
rst -processor
con
I removed ps7 related lines because they are only valid for the first time, aren't they?
Thanks in advance,
Can you explain what 'doesn't work' means? For FPGA command, you don't have to select a target - this command programs the FPGA if it's the only FPGA device on the chain. If there're multiple FPGA devices, then you need to select the correct FPGA device.
I guess target 2 in your case could be A9 #0. If thats the case, your script should have worked, but if it doesn't, we need more details about what's not working. Also, selecting targets by using numeric IDs in a script is not a good practice. Please see https://forums.xilinx.com/t5/Embedded-Development-Tools/Reordering-JTAG-targets/m-p/793513 for more details about programatically selecting targets
Hi @fdpousa,
What error do you get? Is it an error in XSDB or it is not working on HW. If not working on HW, what is the behaviour?
I am surprise that you don't have to change the target... You cna see the PL and the PS on the same target number (i.e. 2)?
Florent
Florent
I haven't got any error... Simply doesn't work. Maybe it could be related with the target number that you mentioned, I made the second script removing some lines from the first one... How can I know the target for the PS?
