2k17_hghspdsrmg
Xadc output
Is it possible to interface the Xadc tdata (or any other data output port) with a another ip block like the multiplier or adder/subtractor?
2k17_hghspdsrmg
From my understanding of that video I would not be able to use axi4 stream to dsp48 or multiplier I would have to use drp. Is that correct?  I'm trying to output current signals from xadc axi4 stream tdata port is this something I need to configure in sdk or verilog?
2k17_hghspdsrmg
I usually see the block connected to axi dma but not a adder/multiplier/dsp48.
