Voyager
Voyager
Xapp1026 TCP TX Throughput test
Hey
I was implementing the xapp 1026 tutorial on the SP601 board using EDK 13.1. All the tests work fine. The echo server is perfect , the web server is fine , the RX through put test also is fine ( getting a BW of 24mbps ) but some how the TX throughput test is not working. PC is not able to pick up any transmissions from the board.  Is there any specific settings needed just for the RX throughput test as compared to the TX through put test?
Any help would be great.
hi,
i used that xapp too, and every feature works fine. if you follow the document step by step, there shouldnt be a problem.
by the way, changing ip and ports may help you
If all the other feature work, then your hw must be set up fine. Can you check the config_apps.h file to make sure that the TXPERF_CLIENT is set to 1. if not this wont run
