tom.binko
Xil_printf Problem (outputting numbers)
Vivado 2017.4, SDK
SDK Code:
#include <stdio.h>
#include "platform.h"
#include "xil_printf.h"
#include "xil_types.h"
#include "xparameters.h"
u32 *baseaddr_p = (u32 *)XPAR_MY_MULTIPLIER_0_S00_AXI_BASEADDR;
int main()
init_platform();
xil_printf("Multiplier Test\n\r");
// Write multiplier inputs to register 0
*(baseaddr_p+0) = 0x00020003;
xil_printf("Wrote: 0x%08x \n\r", *(baseaddr_p + 0));
// Read multiplier output from register 1
xil_printf("Read : 0x%08x \n\r", *(baseaddr_p + 1));
if (*(baseaddr_p+1) == 0x6)
  xil_printf("6 OK\n\r");
xil_printf("End of test\n\n\r");
return 0;
Output:
SREC SPI Bootloader
Loading SREC image from flash @ address: 00600000
Bootloader: Processed (0x)000001ab S-records
Executing program starting at address: 00000000
Multiplier Test
Wrote: 0x%
Read : 0x%
6 OK
End of test
The output doesn't contain my values.  The % isn't being thought of as a control character that converts numbers to output, instead it is sent as a character.
I've tried playing around with the %08x, trying %8x, even trying a %d with just a number, and it still won't show me a number when I need it.  This code worked fine in 2017.2.
Any ideas?  Has anyone seen this problem in this version?  I've looked at the xil_printf.c  in standalone_v6_5 and it shows some syntax errors.  I didn't touch the file.  It is a library source, so I thought it was correct.
Tom
hbucher
@tom.binko try %08lx
tom.binko
Nope, still a problem:
SREC SPI Bootloader
Multiplier Test
Wrote: 0x%x
Read : 0x%x
6 OK
End of test
#include <stdio.h>
int main()
init_platform();
xil_printf("Wrote: 0x%08lx \n\r", *(baseaddr_p + 0));
xil_printf("Read : 0x%08lx \n\r", *(baseaddr_p + 1));
return 0;
hbucher
@tom.binko xilprintf is not a full compliant printf replacement.
Try only %lx
Btw is my_multiplier a his component by any chance?
tom.binko
No again:
SREC SPI Bootloader
Bootloader: Processed (0x)000001aa S-records
Multiplier Test
Wrote: 0x%x
Read : 0x%x
6 OK
End of test
#include <stdio.h>
int main()
init_platform();
xil_printf("Wrote: 0x%lx \n\r", *(baseaddr_p + 0));
xil_printf("Read : 0x%lx \n\r", *(baseaddr_p + 1));
return 0;
tom.binko
My multiplier is a simple custom AXI IP:
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
entity multiplier is
    port(
            clk : in  std_logic;
            a   : in  std_logic_vector(15 downto 0);
            b   : in  std_logic_vector(15 downto 0);
            p   : out std_logic_vector(31 downto 0)
end multiplier;
architecture IMP of multiplier is
begin
    process (clk)
    begin
        if (clk'event and clk = '1') then
            p <= a * b;
        end if;
    end process;
end IMP;
It seems to do the job, since I do a test for it near the end of the .c file (posted earlier).
ericv
@tom.binko
you may have a better luck with %p instead of %x or %lx
tom.binko
%p That didn't work either.
Tom
johnmcd
What optimization are you using for compile?
I suggest you try using optimization -O0.
If -O0 works, I suggest you add 'volatile' to instruct the compiler to always access the memory location.
Or, use something like the following which uses 'volatile':
#include "xil_io.h"
#define BASE_ADDR XPAR_WHATEVER
Xil_Out32(BASE_ADDR, 0x00020003;
xil_printf("Wrote: 0x%08x\n\r", Xil_In32(BASE_ADDR));
xil_printf("Read: 0x%08x\n\r", Xil_In32(BASE_ADDR+4));
tom.binko
I'd agree that solution should work, however, I'm still getting the same output problem:
SREC SPI Bootloader
Bootloader: Processed (0x)000001b0 S-records
Multiplier Test
Wrote: 0x%
Read: 0x%
End of test
With this code:
#include <stdio.h>
#include "xil_io.h"
#define BASE_ADDR XPAR_MY_MULTIPLIER_0_S00_AXI_BASEADDR
//u32 *baseaddr_p = (u32 *)XPAR_MY_MULTIPLIER_0_S00_AXI_BASEADDR;
int main()
init_platform();
Xil_Out32(BASE_ADDR, 0x00020003);
//*(baseaddr_p+0) = 0x00020003;
//xil_printf("Wrote: 0x%p \n\r", *(baseaddr_p + 0));
//xil_printf("Read : 0x%p \n\r", *(baseaddr_p + 1));
//if (*(baseaddr_p+1) == 0x6)
// xil_printf("6 OK\n\r");
return 0;
I think I'm still stuck.
tom.binko
Looks like I have a syntax error in Xil_printf (see attachment).  I'm not sure why.
johnmcd
Sorry, trying to catch up on emails.
If you hover or click on the '?', what is displayed?
You should also see warnings in the console for the bsp build, and the SDK 'problems' tab should show you what the warning is.
tom.binko
When I opened SDK up again today, the ? has now become a ! (still underlined in squiggly yellow)and it shows:
passing argument 1 of 'outs' makes pointer from integer without a cast [-Wint-conversion]
(ie. it is no longer a syntax error, but a cast warning)
In the problems tab the following shows up:
Description Resource Path Location Type
expected 'charptr {aka char * const}' but argument is of type 's32 {aka long int}' xil_printf.c /hello_world_bsp/microblaze_0/libsrc/standalone_v6_5/src line 63 C/C++ Problem
I believe the build goes through because it is just a warning.
Tom
ericv
Hi @tom.binko
One way you can get around that xil_printf() problem is to rely on the "C" library for the conversion:
e.g.
char Str[#];
  sprintf(&Str[0], format, ... );
  xil_printf("%s", &Str[0]);
You could also use vprintf().
With a "C" pre-processor macro defining xil_printf() with your own custom  vprintf() based function, you'll keep all the xil_printf() calls in your code as is.
You can even call xil_printf() in that function if you #undef xil_printf() before using it.
